Holley Fuel Pressure Regulator - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-19-2016, 02:35 PM Thread Starter
chadd925's Avatar
Quoted: 16 Post(s)
Currently running a Holley spread bore and I'm having a hot start issues due to flooding. From what I have read Holley's can be temperamental with fuel pressure, and I would like to put in a regulator. Never done this before, currently have a stainless pump to carb fuel line, any recommendations on how to keep this clean? 67' 400
chadd925 is offline
post #2 of 2 (permalink) Old 08-20-2016, 12:16 PM
First make sure it's due to flooding (recommend putting a fuel pressure gauge in-line just prior to the carb inlet so you can see what the pressure really is), and make sure your needle(s) and seat(s) are in good condition (ethanol fuel can attack rubber-tipped needles so that they don't seal well). I don't know what Holley recommends for inlet fuel pressure - I run my QJet at around 6.5.
A hot start problem can be caused by lots of things. Perhaps it's just boiling all the fuel out of the bowls via the vents and you're having to wait for the fuel pump to fill them back up again. My point is, try to find what's really causing your problem. "Just trying things" can get expensive, and can also be frustrating.
Fuel pressure issue... what to check? r3d05GTO Service, Maintenance and Technical Discussion 0 08-26-2015 02:05 AM
Fuel Pressure Problem? 42867Goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 12-26-2011 05:17 PM
Stock fuel pressure OrbitOrange 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 07-03-2011 12:10 PM
Fuel pressure dropping 69-JUDGE 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 09-20-2010 03:56 PM
fuel pressure regulator? yousaygo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 07-02-2010 05:11 PM
