How can I confirm my balancer is fully seated? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-03-2019, 12:08 PM Thread Starter
Quoted: 17 Post(s)
Guys,
I just installed my new balancer on a Pontiac 400 I'm building and I'm wondering how I can confirm the balancer is fully seated. I lined up the keyway on the crank and the balancer seemed to go on without and issue. I GENTLY tapped it on with a rubber mallet and then tightened the crank bolt to the proper torque. The crank bolt seemed to thread in 3/4-1" prior to getting tight, so it seems the balancer was on properly, but my OCD is getting the best of me. I've included a pic of the balancer as installed and it doesn't look to me like there is much room for it to go on any further but I just wanted to see if there was a way to confirm it is fully seated. Thanks for taking a look.
Mike
Name:	new blancer pic.jpg
70conv is offline
post #2 of 6 (permalink) Old 04-03-2019, 12:40 PM
Quoted: 54 Post(s)
If you torqued it to 160 ft-lbs, I don't see any way it could possible go any farther.
https://butlerperformance.com/p-3488...ine-specs.html
bigD is online now
post #3 of 6 (permalink) Old 04-03-2019, 01:32 PM
Quoted: 98 Post(s)
This^^^^. Plus, looking at the pic, it is seated all the way. You are good to go.
post #4 of 6 (permalink) Old 04-03-2019, 02:03 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
looks good
but I am not familiar with the aftermarket parts ...
maybe put your pulley on the crank and water pump and see if they line up ??
Scott
BLK69JUDGE is online now
post #5 of 6 (permalink) Old 04-03-2019, 03:03 PM Thread Starter
Quoted: 17 Post(s)
Thanks guys all good points. That's what I thought but just wanted to be sure. I'll check the water pump pulley to be sure.
70conv is offline
post #6 of 6 (permalink) Old 04-04-2019, 07:36 PM
Lemans guy's Avatar
Quoted: 54 Post(s)
I agree, good work. Nice balancer too.
Lemans guy is offline
Clutch not fully disengaging after 3 runs rnoswal Drive train, suspension, alignment and brakes. 5 04-24-2010 12:47 AM
Carb will not open fully.......TNFS jim's68 1964-1974 Tempest, Lemans & GTO General Discussion 5 07-16-2006 09:50 AM
