in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
The 1964-1974 Pontiac Tempest, Lemans & GTO
1964-1974 Tempest/LeMans/GTO Engine Tuning
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 30
Go to page
Go
30
Sticky
Pontiac Oil Pan - Making It Deeper
PontiacJim
Oct 4, 2020
2
20
6K
Feb 13, 2023
by
ponchonlefty
Sticky
Pontiac Windage Tray & Oil Baffle Tech
PontiacJim
Oct 3, 2020
12
8K
Feb 12, 2023
by
ponchonlefty
Sticky
FUEL PUMP - OPERATION & TESTING IT
PontiacJim
Jun 11, 2022
6
5K
Jun 18, 2022
by
PontiacJim
Sticky
Pontiac Oil Pan Tech - Fill Levels
PontiacJim
Sep 30, 2020
13
8K
May 25, 2022
by
PontiacJim
Sticky
Main Bearing Check
PontiacJim
Nov 22, 2020
18
8K
Apr 3, 2022
by
geeteeohguy
Sticky
Pontiac Tune-Up Specs 1955-70
PontiacJim
Sep 26, 2020
6
5K
Mar 18, 2022
by
PontiacJim
Sticky
Degreeing a Cam - the process
Nov 15, 2021
6
2K
Nov 17, 2021
by
armyadarkness
Sticky
A better way for Spring/Summer Cooling System Service
Lemans guy
May 16, 2021
3
2K
May 17, 2021
by
Sticky
GTO Tuning and Setup Tips
lars
May 21, 2007
2
3
56
84K
Dec 1, 2020
by
RMTZ67
Sticky
400 Dyno Test Data with Holley & Q-Jet Comparison
lars
Mar 24, 2012
2
21
36K
Aug 7, 2020
by
Mine'sa66
Sticky
(re)Building my engine - finally
Sep 30, 2017
3
4
5
98
20K
Jun 28, 2020
by
Mine'sa66
Sticky
Central Virginia Machine Service (CVMS) Negative Review
Goat Roper
May 22, 2016
5
6
7
122
46K
Apr 26, 2018
by
Goat Roper
Sticky
Central Virginia Machine Service Rip - Off
zrsteve
Dec 6, 2016
13
11K
Dec 18, 2016
by
Goat Roper
J
Need help/advice on Plugs- help and oil, rear lift please
joeyc6365
Mar 20, 2024
2
210
6d ago
by
Redgoat65
Speedmaster Ram Air IV cylinder head install
TxGTO69
Feb 14, 2024
55
2K
Mar 20, 2024
by
TxGTO69
H
Spark plugs in a 30 over 400
Hallett Dave
May 22, 2016
23
25K
Mar 20, 2024
by
joeyc6365
Adding Vintage Air to my 70 GTO
Lok
Jan 14, 2024
22
932
Mar 14, 2024
by
Lok
M
Tri-power to 4bbl on 350 stock
Mleads310
Dec 12, 2023
2
42
2K
Mar 13, 2024
by
lust4speed
Out of shape 70 Gto
Evan's 70
Mar 11, 2024
8
361
Mar 11, 2024
by
lust4speed
C
Running Hott want crank
Corvetteman
Mar 7, 2024
21
532
Mar 10, 2024
by
geeteeohguy
C
Ticking noise
Corvetteman
Mar 8, 2024
3
234
Mar 9, 2024
by
lust4speed
Tri power carb adjustment help!
Oliver1232
Feb 18, 2024
34
816
Mar 7, 2024
by
armyadarkness
Is 60 over a safe option for a street car? (1971 Pontiac Lemans Sport)
71notagto
Mar 6, 2024
3
205
Mar 6, 2024
by
geeteeohguy
Guide to install tri power?
foney_email
Feb 25, 2024
16
506
Mar 2, 2024
by
foney_email
bare 400 block - worth it?
ylwgto
Feb 23, 2024
40
1K
Feb 29, 2024
by
ylwgto
R
Hypertectic pistons and stock rods in street 455
ratfink1
Feb 23, 2024
8
365
Feb 24, 2024
by
Lok
R
ram air exhaust manifold fitment ?
ratfink1
Feb 21, 2024
4
332
Feb 21, 2024
by
Baaad65
YOU'RE NOT RUNNING A CATCH CAN? HERE'S WHY YOU SHOULD.
armyadarkness
Oct 13, 2023
2
71
3K
Feb 20, 2024
by
Typical Vally pan PVC question.
Oliver1232
Feb 16, 2024
71
2K
Feb 19, 2024
by
geeteeohguy
Oil , dip stick question 🙋‍♂️ getting the right one
Oliver1232
Feb 9, 2024
19
895
Feb 16, 2024
by
Sick467
Hard start issue
Notagoat
May 2, 2023
23
1K
Feb 14, 2024
by
Notagoat
1966 TriPower GTO, Fuel starvation symptom on center carb
66CHEEVO
Dec 4, 2023
6
852
Feb 12, 2024
by
Jetblack
Point Distributor Rebuilder...or Rebuild Myself?
Sick467
Dec 30, 2023
36
2K
Feb 10, 2024
by
Baaad65
Advice on what the stick says vs what I put in ..... OIL CAP question
Oliver1232
Feb 9, 2024
3
291
Feb 9, 2024
by
O52
B
428 ?
Baldric
Feb 28, 2023
17
2K
Feb 9, 2024
by
ponchonlefty
R
Compression on 400 with 72cc heads
ratfink1
Jan 30, 2024
2
127
4K
Feb 8, 2024
by
Sick467
Timing question for my Le-goat.
Oliver1232
Feb 5, 2024
5
544
Feb 7, 2024
by
geeteeohguy
Points and condenser to electronic ignition conversion
2jamesb2
Aug 11, 2022
29
5K
Feb 6, 2024
by
geeteeohguy
The Flat Tappet State of Affairs
GTO44
Jan 9, 2024
13
837
Jan 28, 2024
by
fishwater
W
voltage question with MSD Distributor
wooftfd
Jan 24, 2024
3
325
Jan 25, 2024
by
wooftfd
N
Comparison! - 068 cam idle and 067 cam Idle for Reference
NYGTO2018
Jan 18, 2024
28
3K
Jan 25, 2024
by
NYGTO2018
R
'71, 96 heads vs 6-8 heads on 455
ratfink1
Jan 23, 2024
1
180
Jan 23, 2024
by
lust4speed
R
428 vs 455
ratfink1
Jan 22, 2024
3
662
Jan 22, 2024
by
Jim K
L
Water pump plate clearance
leet
Oct 21, 2023
43
2K
Jan 21, 2024
by
GtoFM
Trying to start car on '66
jspete-66GTO
Jan 11, 2024
39
2K
Jan 19, 2024
by
Scott06
C
65 GTO w/455 HP lots of goodies, dual quad Fitech EFI, CNC Alum. heads. med.wild cam etc. WOT no load problem
clintonmitchell2023
Jan 11, 2024
3
553
Jan 12, 2024
by
geeteeohguy
R
455 YA code?
ratfink1
Jan 9, 2024
4
628
Jan 10, 2024
by
ratfink1
R
Compression test, '67/335hp
ratfink1
Jan 5, 2024
5
526
Jan 7, 2024
by
lust4speed
1
1 of 30
Go to page
Go
30
13.4K
posts
4.3M
views
1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance
Show Less
Join Community
Grow Your Business
Forum Staff
View All
Top Contributors this Month
View All
lust4speed
Lok
C
Corvetteman
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Deals Forum
40+ members
Home
Forums
