How to ID 69 Ram Air III Heads - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-26-2018, 01:03 PM Thread Starter
Roqetman's Avatar
Quoted: 16 Post(s)
Good afternoon, my 65 GTO has 69 Ram Air III heads... Im told by the previous owner. Im going to install new header exhaust gaskets and wanted to be sure I get the right size and shape for the exhaust ports. I believe these heads should have a 48 cast on the center exhaust ports but... the numbers are not very legible. How can I tell for sure, is there another number to go by? Also, what type gaskets are recommended for iron heads and Hooker Headers? Thanks!
Roqetman is offline
post #2 of 3 (permalink) Old 03-26-2018, 06:42 PM
Step 1) Look for the date code. This is 4-characters, 1 letter followed by 3 digits. It may be 'inside' under the valve covers. The letter indicates which month they were cast with A being January, etc., followed by a 2 digit day, and a 1 digit year. The engine foundry 'switched over' and started making parts for the next model year about mid-year previous, so for model year 1969 your date code should either begin with an A-G and the last digit should be a 9, or it should be higher than 'G' and end with an 8.
You have to nail the model year first because they 'reused' the other casting numbers on the exhaust ports to mean different things in different years.
Step 2) For RA III 1969, the head casting should be either 48 (manual transmission car) or 62.
As for header gaskets, I've been using Remflex with very good results.
post #3 of 3 (permalink) Old 03-30-2018, 04:33 PM Thread Starter
Roqetman's Avatar
Quoted: 16 Post(s)
Bear, Thanks!
Roqetman is offline
1969 RAM AIR III heads mrvandermey 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 44 03-18-2014 05:32 AM
69 Ram Air III Piece shelbee350 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 01-31-2013 06:34 PM
ram air III parted out! 1964F-85 Member Introductions 1 02-15-2010 07:32 PM
1970 ram Air III heads Eric Animal 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 11 04-25-2008 04:09 PM
