I Need a New Distributor - Pontiac GTO Forum
 9Likes
post #1 of 14 (permalink) Old 09-29-2018, 03:24 PM Thread Starter
Mr.409's Avatar
Quoted: 9 Post(s)
Hello Guys
i need a new distributor
Does anyone have a good recommendation which distributor is the best for a Stock 400 ci 1973 Pontiac Engine is
Engine Cast Number: 481988
Thanks for information from you
Mr.409 is offline
post #2 of 14 (permalink) Old 09-29-2018, 05:18 PM
Quoted: 54 Post(s)
Originally Posted by Mr.409 View Post
Hello Guys
If you wanna upgrade to a big cap HEI, the DUI brand is said to be the best. But they're just over $300, from Summit. Summit also sells some cheaper brands, such as Pertronix.
Some like to use a stock type points dist, but install a Pertronix Ignitor elec unit in place of the points. But, some badmouth the Ignitor units.
https://www.summitracing.com/parts/p...4aAiDQEALw_wcB
Lots of Pontiac guys say that a properly set up & tuned factory points type distributor is plenty good, and more reliable than any aftermarket dist. Back in the 20th century, I used upgraded factory points dist in all my drag cars, and most of the street cars. They worked just fine. They worked good in most all the old Musclecars. i won quite a few races before the HEI came out. Didn't see any reason to switch. My last bracket car came with an HEI. It ran good, so I still use it.
Mr.409 likes this.
bigD is offline
post #3 of 14 (permalink) Old 09-29-2018, 05:21 PM
Quoted: 54 Post(s)
Hello Guys
If your car is running a points type dist, & you swith over to an HEI, keep in mind that you can't use the resistor wire that goes to the coil. The HEI must have a wire with a full 12 volts--no resistor.
bigD is offline
post #4 of 14 (permalink) Old 09-29-2018, 09:47 PM
Quoted: 106 Post(s)
The problem with the DUI distributor is their wires don't fit the 400.
100 bucks is a lot of money for a set of wires that are too short.
I don't see how they can be the best when their wire set is sub par.
Mr.409 likes this.
Goat Roper is offline
post #5 of 14 (permalink) Old 09-30-2018, 11:34 AM
Quoted: 54 Post(s)
Don't think wires come with a DUI HEI.
https://www.summitracing.com/parts/d...w/make/pontiac
I'd buy good Accel or Taylor wires, in a universal set, so I could cut the wires to the length I want.
https://www.summitracing.com/parts/tay-70655/overview/
https://www.summitracing.com/parts/acc-8022acc
Mr.409 likes this.
bigD is offline
post #6 of 14 (permalink) Old 09-30-2018, 11:57 AM
Quoted: 106 Post(s)
The wires don't come with it, the set they make for the Pontiac 400 doesn't fit.
Your idea to make a set from universal is probably the way to go especially with A/C since #2 takes a straight boot.
My goat ran great with the Mallory Unilite but the module took a dump so I swapped it out with the stock unit with a Pertronix and now it runs like crap.
The problem with the Mallory is that it is photo optic instead of magnetic.
Over 100 bucks for the replacement module when the optos are a few cents each.
Of course they pour it as a solid block so you cannot just replace the optos.
Tossed that POS in the recycle bin since it would be 250 bucks for a replacement and a spare module.
Less than 200 miles on this distributor and I don't plan on replacing the module every 200 miles.
Mr.409 likes this.
post #7 of 14 (permalink) Old 09-30-2018, 12:24 PM
deanhickey's Avatar
Quoted: 36 Post(s)
That's why I love points, simple and cheap. I don't race so I don't need the high performance. that being said I keep a set in the glove compartment just in case.
Mr.409 likes this.
deanhickey is offline
post #8 of 14 (permalink) Old 09-30-2018, 12:31 PM Thread Starter
Mr.409's Avatar
Quoted: 9 Post(s)
does anyone have an opinion for this part
https://www.ebay.com/itm/HEI-Distrib...EAAOSw3RhZxqwy
Mr.409 is offline
post #9 of 14 (permalink) Old 09-30-2018, 12:50 PM
Quoted: 106 Post(s)
That is the next thing to try, remove the Pertronix and reinstall points.
Mr.409 likes this.
post #10 of 14 (permalink) Old 09-30-2018, 01:27 PM
Quoted: 98 Post(s)
I'm running and have been running the stock points distributors in both my GTO's for nearly 40 years now with no issues. My advice would be to convert your original back to points or buy a decent used stock unit, bolt it in, and go. But then, I like to do things the easy way.
Mr.409 likes this.
I Need Distributor Help DanMinninger 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 8 08-08-2017 05:12 PM
70 gto Distributor replacement 70gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-23-2008 06:58 PM
Distributor opinion squeezedgto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-13-2007 06:26 PM
