Jetting a Rochester Quadrajet - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-17-2018, 12:01 PM Thread Starter
Hi Guys,
I wanted some advice in order to jet my rochester.
Im rebuilding my 65 GTO in France, so when i order parts i prefer not mistake.
My motor is stock 400ci YS except from 0.060inch + piston size.
My carb is a R4-M4MC
The jets are 97.
Primary metering rods 48K
Secondary CH
From what info i sourced something between 70-76 jet size could be a good start.
I know its difficult to guess it, but perhaps someone could put me on the way.... Of jet size or tips on the metering rods size.
I called butler and some parts dealer and couldnt find any info. Even on the website not much info on jet size.
Of course carb is rebuild and everything is in good shape.
Hope someone could giuve some good advice
el_papelitos is offline
post #2 of 3 (permalink) Old 11-17-2018, 02:04 PM
Quoted: 347 Post(s)
The best advice anyone can give you is to purchase a copy of this book: https://www.amazon.com/Rebuild-Modif.../dp/1932494189
The book will be a big help in your tuning as it is more than just jets and hangers.
post #3 of 3 (permalink) Old 11-18-2018, 01:09 PM
+1 on the book recommendation. Cliff is the authority on these carburetors. I'd also recommend installing a good quality wideband/UEGO air-fuel meter so that you'll be able to tell exactly how your mixtures are running without having to guess or read plugs. Reading plugs has gotten a lot more difficult to do since the advent of unleaded fuel and the additives in it.
:patriot: Rochester Quadrajet 4brl My6869gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-27-2015 07:43 PM
Rochester Quadrajet ROGTO67 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 03-21-2013 04:06 PM
Cold start problems with rochester quadrajet. Fuel draining out of carb ? dillon14 1964-1974 Tempest, Lemans & GTO General Discussion 8 07-15-2011 10:55 PM
