Just dyno’d my engine - Pontiac GTO Forum
 9Likes
post #1 of 17 (permalink) Old 06-22-2019, 10:10 PM Thread Starter
Quoted: 17 Post(s)
I just dyno’d my engine today. It’s a 490 CI stroker, 10:1 compression, KRE D-port heads out of the box, edelbrock performer intake with a mild hydraulic Roller cam, 850 vac secondary carb MSD Billet distributor, and Ram air exhaust manifolds. It made 616 HP and 703 ft/lb of torque on pump gas. I was very happy. I was hoping for 550 HP so this was great. The monster torque numbers were really a bonus. This will def make driving my big heavy 70 GTO a lot of fun! Thanks for all the help you guys have provided me over the last year while I assembled this motor, my first build.
Mike
PontiacJim, deanhickey and cij911 like this.
70conv is offline
post #2 of 17 (permalink) Old 06-23-2019, 04:33 AM
deanhickey's Avatar
Quoted: 38 Post(s)
Originally Posted by 70conv View Post
I just dynoíd my engine today. Itís a 490 CI stroker, 10:1 compression, KRE D-port heads out of the box, edelbrock performer intake with a mild hydraulic Roller cam, 850 vac secondary carb MSD Billet distributor, and Ram air exhaust manifolds. It made 616 HP and 703 ft/lb of torque on pump gas. I was very happy. I was hoping for 550 HP so this was great. The monster torque numbers were really a bonus. This will def make driving my big heavy 70 GTO a lot of fun! Thanks for all the help you guys have provided me over the last year while I assembled this motor, my first build.
Mike
Sound like a blast. Hope you upgraded the brakes LOL. post some pictures.
Instg8ter and cij911 like this.
deanhickey is offline
post #3 of 17 (permalink) Old 06-23-2019, 06:34 AM
Quoted: 126 Post(s)
Mike
Mike - Did you build the motor? What stroker kit did you use? Congratulations !
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #4 of 17 (permalink) Old 06-23-2019, 11:30 PM Thread Starter
Quoted: 17 Post(s)
Yes I assembled it. The package was put together by the guys at Kauffman Racing Equipment. They supplied the block and everything. I can’t recall the exact specs of the stroker kit and my paperwork is at my shop. Pretty sure the crank was made by eagle. I told them I wanted a very streetable combo, one that would work with the factory AC on my car, but I wanted min 550 HP. This was the setup they sold me. I did it this way because I wanted to be able to build an engine with my son as a project for us to do. We did it all— file-fit the rings,
Plastiguaged all the clearances, degreed the cam, etc, etc. I’ve spent my whole life working on cars but I never built an engine before. Some skills are applicable to any engine and some things are only unique to Pontiacs so it was a steep learning curve but the guys in this forum were def a big help.
Mike
70conv is offline
post #5 of 17 (permalink) Old 06-24-2019, 08:42 AM
Quoted: 20 Post(s)
you dont even have an idea what kind of fun you will have with that torque on hand. , agree about brakes and power steering....sure if your building with quality meterials that you will do it up right....ENJOY!!! thats what its all about
Instg8ter is online now
post #6 of 17 (permalink) Old 06-24-2019, 12:51 PM Thread Starter
Quoted: 17 Post(s)
Here's the info on the build:
Ohio Crank forged 4.50/3.00
KB Pistons 943-30 4.5 stroke
Eagle Rods 6.700
KRE Heads 85 cc stock heads
MSD Dist. 8528
RPM Performer intake
Comp cam 235/241HR14+4
Trend pushrods 8.800
deanhickey likes this.
70conv is offline
post #7 of 17 (permalink) Old 06-24-2019, 04:28 PM
GTO44's Avatar
Quoted: 37 Post(s)
Very nice! Great numbers with that combo!
I’m putting together a 461 stroker for a customer with similar specs. 4 bolt main 400 block, Butler billet main caps, butler 461 forged stroker kit with eagle rods, eagle crank, butler/ross flat top pistons. Top end will be KRE D ports with a port matched northwinds single plane and holley super sniper. We were going to go with a fairly large tight lash solid roller cam but the power you made with a mild roller cam is amazing. The customer’s goal is 650hp at the crank. Street driven as well as track runs around once a month. Car is a ‘77 trans am.
Again very impressed with the power on your setup! Great job
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #8 of 17 (permalink) Old 06-24-2019, 07:05 PM
Quoted: 347 Post(s)
Eagle Rods 6.700
MSD Dist. 8528
At what RPM's did the engine hit those numbers? Curious as to the RPM you had to spin a 4.5" stroker crank. I want to build a big inch engine at some point in my life as well and on paper I can see 5,800 RPM being a pretty good number to shoot for and not run on the ragged edge.
post #9 of 17 (permalink) Old 06-24-2019, 07:32 PM Thread Starter
Quoted: 17 Post(s)
Peek HP was at 5,400 RPM, peek torque was at 3,600. One question I had was about the oil pressure. It was recorded by the Dyno throughout the run. It started at 60 psi at 3,500 RPM (the lowest RPM the Dyno recorded data) on one run it went down to 42 psi and on the other it went dwin to 32 psi at 5,800 rpm. Is this a reasonable pressure for a Pontiac engine? This is my first Pontiac build. Thanks for your input.
Mike
70conv is offline
post #10 of 17 (permalink) Old 06-24-2019, 09:17 PM
Quoted: 347 Post(s)
Mike
Thanks, better (lower RPM's) than I thought for those kinds of numers.
I personally would be concerned with your oil pressure numbers. Pontiac engines should have 60 PSI above 2500 RPM's. Dropping pressure as RPM's go up is not what you want.
I would discuss this with your dyno man to make sure it was not an equipment fluke. If it is not, then I would be looking for a cause. The rule of thumb is 10 PSI for each 1,000 RPM.
Read this article: https://www.pontiacdiy.com/pontiac-v...-system-guide/
There could be a number of reasons. I am going to just ramble on and throw out ideas to consider.
1st, poor quality oil filter not flowing enough. Butler Pontiac recommends a Wix oil filter.
What oil pump did you use? I used a Mellings 60 PSI pump on a 400 build and had problems. On my present 455 build, I began with a Mellings 60PSI pump. It has a courser quality screen ( larger holes) than the fine screen mesh on the 400 build I did. I feel the fine mesh may have contributed to my problem. Anyway, I then purchased the heavy duty oil pump plate. This is thicker and is designed to provide anticavitation. You can see it and read the description here: https://www.tinindianperformance.com...il-pump-plate/ At the time, Butler Pontiac had a Pro-pump they offered, but only for an 80PSI oil pump. They eventually did put out a Pro-pump for the 60PSI oil pump -so I bought this and will use it on my 455.
What oil pan? If you used a deeper pan, did you get the matching pump pick-up tube/screen? You would have also wanted to check the clearance between the bottom of the pan and bottom of the pick-up screen. Too much space can be a problem as well as sitting too low and not enough space.
Windage tray or screen?
Was the pick-up tube secured in any way to the oil pmp so it could not fall off? If the pick-up tube/screen were to fall off, oil pressure can suffer.
I assume you purchased a new oil pump drive shaft? Never use the factory one. You want an aftermarket hardened pump shaft. The factory piece can break. You can get a simple inexpensive one from most any Pontiac parts supplier or step up and get something more rugged. I went with this one from Nitemare Performance: Standard sleeved & hardened oil pump driveshaft Bear GFR used one and as I recall, you have to check your clearances on that larger end sleeve. He has others as well as the oil pumps & oil pump plates.
That said, I would talk with your dyno guy first. I assume the engine is still out of the car? It would be easier now to pull the pan IF needed than once you get it in the car and could have to take it back out.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
GMCSIERRA35
