Looking for near stock cam replacement - Pontiac GTO Forum
post #1 of 7 (permalink) Old 11-10-2011, 10:25 PM Thread Starter
My buddies 1968 lemans 350 2 barrel with powerglide has a bad cam. Was thinking of going with a Summit sum-k2800 ( Duration @.050 204/214 420/442 lift ) The stock cam was a ( U model ) duration ? Lift 375/410. My questions are would the summit cam cause any spring bind? Will it still idle as smooth as stock?
supercab78 is offline
post #2 of 7 (permalink) Old 11-11-2011, 06:21 PM
Can't answer about the springs. It will not idle AS smooth, but should be OK. You should match a cam with CARB/INTAKE MANIFOLD & REAR GEARS for optimum gain......are you gonna do a valve job also?
Eric Animal is offline
post #3 of 7 (permalink) Old 11-12-2011, 12:06 PM Thread Starter
No not doing a valve job. Compression checks out ok. There is a pretty good jump on the intake lift. We may just go with a standard replacement from a parts place so he has a good idle.
post #4 of 7 (permalink) Old 11-12-2011, 01:20 PM
The 254 cam has an advertised I/E duration 269/277 with a LSA of 113, the Summit K2800 has an advertised I/E duration 262/272 with a LSA of 112.
The idle may be a little choppy with a 112 LSA but not noticeable. The K2800 cam or a 066 would be a good replacement for the 254. The springs should be ok,
05GTO is offline
post #5 of 7 (permalink) Old 11-18-2011, 06:48 PM Thread Starter
Thanks for the input. We decided to go with one closer to stock.
post #6 of 7 (permalink) Old 11-18-2011, 10:25 PM
That's not a powerglide, unless someone has swapped in a chevy transmission. Pontiac 2-speed automatics (Super Turbine 300) are different transmissions than powerglides.
You should be ok, spring bind wise. Biggest concern is static compression ratio and tendency towards detonation. If you're changing the cam anyway, it might be wise to use one with a later intake close event to stay out of trouble. Which heads does it have?
post #7 of 7 (permalink) Old 11-19-2011, 02:51 PM
melling still makes stock cams like they did for the factory.
pontiac is offline
LS9 Crate into 2006 GTO, degree of difficulty? 9"Moser replacement for stock GTO IRS tem2006LS2plus Engine Discussions 23 07-14-2011 06:26 PM
Best Stock Size Replacement For... BlownGTO Drive train, suspension, alignment and brakes. 0 03-15-2007 05:06 AM
