New carb, now car wont stay on. - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-27-2016, 05:47 PM Thread Starter
Recently purchased a 1969 GTO 400 with TH400. Car looks great but needs some work to get it to be a "daily driver". I recently took out the weber carb as it was not working. I replaced it with a Rochester Quadra jet. The problem now is that the car starts, but wont stay on. Even after letting it warm up it wont stay on. Any suggestions out there? Would i need to mess with the timing now that installed a new carb? How about vacuum lines? Also new carb has a "pull up" choke, sorry gents im not familiar with this type, can someone explain? Help gents
Sandgoat69 is offline
post #2 of 3 (permalink) Old 07-27-2016, 06:32 PM
Quoted: 361 Post(s)
So by new carb, you mean it is newly rebuilt?
Assume you mean it won't run (stay on) when you let it idle? But it will run when you have the engine raised higher than idle?
Have you set your idle screw?
Did you adjust your mixture screws?
Are your vacuum lines hooked up?
You should not have to mess with the timing if the car was running before.
How about a few pictures?
post #3 of 3 (permalink) Old 08-03-2016, 07:13 PM Thread Starter
Thanks for your answer PontiacJim. Got the car running. Is there a way to find out what cam is in the engine without having to take it out?
Car wont start mattys05 2004-2006 GTO General Discussion 3 06-12-2014 10:16 AM
lights stay on wont turn off after the 20 seconds or so countdown........ pctek Service, Maintenance and Technical Discussion 1 04-15-2011 06:07 PM
replaced intake and carb starter wont work now tattoosrock 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 01-23-2010 07:52 AM
car wont start 740tank Service, Maintenance and Technical Discussion 4 11-22-2009 01:48 AM
Both fans stay on after turning of car primerGTO Service, Maintenance and Technical Discussion 5 02-14-2007 02:39 AM
