no more Edelbrock dual quads? - Pontiac GTO Forum
 4Likes
  • 1 Post By PontiacJim
  • 3 Post By Instg8ter
post #1 of 6 (permalink) Old 05-13-2019, 11:06 AM Thread Starter
michaelfind's Avatar
Quoted: 12 Post(s)
Is it true that Edelbrock is no longer making the P65 or 54501 dual quad manifold for Pontiacs? Are there other aluminum stock height dual quad manifolds being manufactured?
Thanks for any help.
michaelfind is offline
post #2 of 6 (permalink) Old 05-13-2019, 05:40 PM
Quoted: 347 Post(s)
Unknown. But Ebay always has a bunch, so not really an issue.
michaelfind likes this.
post #3 of 6 (permalink) Old 05-14-2019, 12:17 PM Thread Starter
Quoted: 12 Post(s)
Thanks PontiacJim. I took your advice and started looking on Ebay, then to my surprise found one at walmart .com. Really! Shocked me they would have anything like that.
post #4 of 6 (permalink) Old 05-16-2019, 03:51 PM
Quoted: 98 Post(s)
I see Offenhauser 2X4 Pontiac intakes all the time at swap meets. A buddy ran one on his 455 for years with dual AFB's on his '66 GTO....just cleared the hood with small air cleaners. Car made a TON of power, too.
post #5 of 6 (permalink) Old 05-17-2019, 02:27 PM
Quoted: 20 Post(s)
im running the Offy with dual 600 demons for clearance. even had to put 1" risers to make the seal on the RA pan. Like GeeTee says it gives you all the power youll ever need on the street. it takes a minute to get the carbs right and the sequence bar adjusted. Also learn to not just floor the pedal, the single stage tends to like to be eased into not to say it wont still shred a tire without brake from a 20 roll. with that said and the carbs right it accelerates like a 500hp sewing machine, carbs coming on between the shift in sequence, and pulls like an elephant all the way through up and past 100, torque at hand is a wonderful thing.
ID:	119023   Click image for larger version
ID:	119025   Click image for larger version
ID:	119027   Click image for larger version
Instg8ter is online now
post #6 of 6 (permalink) Old 05-18-2019, 03:12 PM Thread Starter
Quoted: 12 Post(s)
Thanks guys. I appreciate the input. I do see lots it the offenhauser manifolds available. I may end up using the after all. I believe the offy is single plane. Is that right. The edelbrock is dual plane and I have read that is best for keeping the power band in the lower ramp range. Good to know on the hood clearance too. Instig8ter, I love the photos. I still can't tell how you attached the top part of the ram air pan to the bottom part you fabricated. What did you use?
1964 Pontiac Offenhauser Dual Quads - Bypass built into water neck? Dual Tempests 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 06-21-2018 02:35 PM
1964 Pontiac Offenhauser Dual Quads - Bypass built into water neck? Dual Tempests Engine Discussions 1 06-17-2018 03:15 PM
Edelbrock Torker II/ Edelbrock Heads JeffW 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 12-16-2015 06:08 PM
Ram air dual quads? Instg8ter 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 11-10-2013 11:13 AM
Dual quads? Pontiacpurebrred 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 29 07-15-2011 05:06 PM
