Oil filter housing for '74 GTO - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-07-2016, 01:19 AM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
I need to get a 90 degree oil filter housing for my '74 GTO to get clearance on longbranch exhaust manifolds. My stock oil filter housing is a 110 degree part and the angle makes the installation of the oil filter not fit. I will be using an oil filter housing adapter from RARE to clear the LB manifolds, but it only works with the 90 degree part.
Any suggestions on best places to get a 90 oil filter housing?
Thanks.
Red74Goat is offline
post #2 of 7 (permalink) Old 07-07-2016, 08:46 AM
pjw1967's Avatar
An alternative might be what I did 21 years ago. The guys that rebuilt my '67 GTO put on Hooker headers. When I crawled under the car to do my first oil change, I found that the standard oil filter would not come out once it was unscrewed from the housing. Surprise! I tried a remote set up with two lines running to an adaptor but one of the lines chafed on the upper control arm. So being the foolish person that I am, I went to the local parts store, got the correct filter, and then started opening up other filter boxes till I found a narrow one with the same dia gasket. Turned out it was a Purolator for a 5.7 Cadillac. Slipped right in between the header pipes. I don't remember the number. But what is on there now is a Pennzoil PZ28. Nary a problem in 21 years.......
pjw1967 is offline
post #3 of 7 (permalink) Old 07-08-2016, 01:13 AM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
pjw thanks for the suggestion. Interesting idea looking for oil filter based on gasket diameter instead of just getting the one normally used on a specific vehicle.
post #4 of 7 (permalink) Old 07-09-2016, 09:30 AM
pjw1967's Avatar
Here are some photos but they don't tell you much. Filter hangs straight down. Here is a cross reference link for an HL3506. JIFFY-LUBE HL3506 - Alternative oil filters
As you can see there is some road grime on it but no leaks.
pjw1967 is offline
post #5 of 7 (permalink) Old 07-10-2016, 11:32 AM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
pjw thanks for the follow-up and taking/posting photos of your setup.
post #6 of 7 (permalink) Old 07-10-2016, 10:20 PM
Quoted: 100 Post(s)
Go on the AMES forum and put in a call-out for the right adapter. A member will help you out. I always go to a bigger filter when possible, but never smaller. Get the right adapter so you can run a good size filter. I ran into this on my '66 GTO 36 years ago and ended up installing a very ugly but functional remote filter. Worked very well, and the filter was right on my firewall. Now, as a grown up, I'd just install the right adapter to the block!
post #7 of 7 (permalink) Old 07-11-2016, 12:33 AM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
Thanks geeteeo on the ideas for locating the part at AMES forum, I can give that a try.
What motor oil and oil filter to use? IcemanGTO 2004-2006 GTO General Discussion 22 11-11-2016 04:04 PM
Preferred Sparkplugs/Oil/filter '67 400HO GTO Grant1969 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 12-12-2014 08:56 AM
1968 GTO Fuse box Oil filter removal djn789 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 07-13-2010 10:27 AM
oil filter housing --by pass or not khinton 1964-1974 Tempest, Lemans & GTO General Discussion 5 03-17-2009 05:00 PM
