Oversized Ram Air III Exhaust options. - Pontiac GTO Forum
post #1 of 9 (permalink) Old 12-30-2012, 12:25 PM Thread Starter
joesweeting's Avatar
I ordered from R.A.R.E. ceramic coated 68-72 oversized Ram Air III exhaust. I currently have hooker competition headers that run to 3" exhaust.
They do sell part number SSP-30 for connecting to a 3" system. Is this the best option?
They also offer ceramic coatings as an option on part SSP-30, are there any special consideration for welding on ceramic coating?
Thanks,
Sent from my ADR6425LVW using AutoGuide.Com Free App
joesweeting is offline
post #2 of 9 (permalink) Old 12-30-2012, 01:33 PM
Quoted: 98 Post(s)
A 3" system is less effective at scavenging the exhaust gasses than a 2 1/2" system unless you are putting out 550 HP or more. I would recommend a dual 2.5" system with a cross-over pipe.
post #3 of 9 (permalink) Old 12-30-2012, 03:51 PM
No need for that size exhaust on a N/A engine unless you are over 500 or so cu in. Why run 3" exhaust anyway if you are going to blow through cast iron manifolds?
post #4 of 9 (permalink) Old 12-30-2012, 05:43 PM Thread Starter
Thanks for the info
The previous owner put 3" exhaust and headers on the vehicle. The headers leak and are a pain to work with so I decided to go with the oversized factory style exhaust.
I can replace the remaining exhaust system for about $600.
They do sell a SHP-6 2.5" Short Mandrel Headpipe for $99
Can I use the 2.5 head pipe and fabricate a connection to my existing 3" system?
Thanks,
Joe
post #5 of 9 (permalink) Old 12-30-2012, 08:10 PM
They do sell neck down sections you could splice in to connect your existing exhaust system. Maybe inquire with the vendor before you order to see if they can hook you up so it's all ready to bolt on.
post #6 of 9 (permalink) Old 12-30-2012, 09:35 PM Thread Starter
RARE does sell SSP-30 to connect the oversized factory Ram Air exhaust to 3" exhaust pipes.
http://www.ramairrestoration.com/b-s...y-headers.html
I'm was planning on adding this to my order.
Another question is should get the SSP-30 ceramic coated too?
Are there any special procedures for welding on ceramic?
Thanks,
Joe
post #7 of 9 (permalink) Old 12-31-2012, 09:55 AM
You'll have to grind the ceramic coating off to weld. Maybe have RARE weld on some flanges so you can bolt on. Or use clamps.
post #8 of 9 (permalink) Old 12-31-2012, 10:52 PM Thread Starter
Thanks for the info
post #9 of 9 (permalink) Old 01-15-2013, 06:30 PM Thread Starter
Parts should be here Saturday. Went with the 2.5 inch pipes going back to the cross member will use a reducer to connect the 2.5 inch pipes to the 3 inch exhaust system.
here's the options from the 70 I'm looking at clanceman427 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 06-07-2012 02:40 PM
GTO options Roger that 1964-1974 Tempest, Lemans & GTO General Discussion 7 03-10-2010 10:50 AM
Exhaust options for 05 GTO jwengel Service, Maintenance and Technical Discussion 3 06-17-2005 10:11 PM
SPINTECH EXHAUST SUCKS, looking for help on exhaust options KERLS04 2004-2006 GTO General Discussion 6 05-31-2005 09:10 AM
