please help with head casting number - Pontiac GTO Forum
post #1 of 16 (permalink) Old 01-05-2013, 10:24 PM Thread Starter
Can't make out the casting number. Please help. This is my first post. Car is a 70 400 gto 4 speed if it matters.
rjinator is offline
post #2 of 16 (permalink) Old 01-06-2013, 12:01 AM Thread Starter
anyone?? from what i have looked up i should be looking for a 11 or 12 but this looks like a 7
rjinator is offline
post #3 of 16 (permalink) Old 01-06-2013, 07:12 AM
rickm's Avatar
Quoted: 5 Post(s)
in the upper right corner of your picture of the head, there is another casting. clean it off and try to read it...
rickm is offline
post #4 of 16 (permalink) Old 01-06-2013, 07:29 AM
allpawl66's Avatar
I would say 11 .
allpawl66 is offline
post #5 of 16 (permalink) Old 01-06-2013, 07:19 PM
Icefan71's Avatar
The 1 looks pretty clear. Other # looks like a 2 to me. What does the passenger side head say? If its the original motor and like you say its a 70 GTO 400 4 speed, then it should be #12 heads. According to the chart in the link #12 were on stick cars, 13 automatics. #11 heads were small valve heads on 350 2 bbl engines.
Pontiac Heads
Icefan71 is offline
post #6 of 16 (permalink) Old 01-06-2013, 09:15 PM Thread Starter
The pass side is near impossible to read. The exhaust port to the right of the head bolt in the picture has two "2"s stamped (not cast) into it.
rjinator is offline
post #7 of 16 (permalink) Old 01-06-2013, 11:04 PM
In your original photo, the upper right corner, on the rail just below the valve cover, there's a 4 character code. I can't read it in the photo --- what does it say?
post #8 of 16 (permalink) Old 01-07-2013, 08:37 AM Thread Starter
it really hard to read but it looks like 'a160'
rjinator is offline
post #9 of 16 (permalink) Old 01-07-2013, 09:52 AM
68greengoat's Avatar
That would be January 16th 1970. Head casting numbers that started with a
"1" were 11, 12(manual and depending on the engine code, RAIII), 13(auto), 15(455) and 16. None started with a 7.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #10 of 16 (permalink) Old 01-07-2013, 09:57 AM Thread Starter
awesome. thank you. that means its an all numbers matching engine. so how do i go about finding out if its a 11, 12 or so on?
rjinator is offline
Block Casting Number Question jedward1 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 02-16-2012 01:05 PM
455 block casting number picture par4n1 1964-1974 Tempest, Lemans & GTO General Discussion 10 01-18-2012 09:11 PM
1964 GTO Rear axle casting number ID mike64gto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 10-06-2011 09:30 PM
Head Casting Number Help dillon14 1964-1974 Tempest, Lemans & GTO General Discussion 12 04-07-2011 04:49 AM
Diff casting number location DrBoeing 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 05-02-2010 10:38 AM
