Push Rods - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-14-2019, 10:15 AM Thread Starter
Quoted: 5 Post(s)
Push Rods
Hello, does anyone know the length of the pushrod when using Edelbrock D port heads on a 65 389? Cam is an SP7, replacement for the 068.
mdbs9337 is offline
post #2 of 2 (permalink) Old 05-14-2019, 07:14 PM
Quoted: 347 Post(s)
Purchase a pushrod checking tool and measure it yourself to ensure you get the correct length so your rocker arm geometry is correct - don't guess or rely on others as engines can be different with regards to lifter type/brand, valve installed heights, rocker arm ratio's, machine work, head gasket thickness, etc.. Then order the length you need.
Lifters, push rods and valves for cam Dawson Babb Engine Discussions 0 07-15-2018 10:17 PM
Is it normal for push rods to have spring? EdR 1964-1974 Tempest, Lemans & GTO General Discussion 2 03-08-2015 04:36 PM
No oil coming up thru the push rods ??? jimmy328 1964-1974 Tempest, Lemans & GTO General Discussion 4 11-07-2014 10:30 AM
push rods and rocker arms Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 17 03-14-2011 10:39 AM
valve springs, push rods and rocker arms Richtenb Engine Discussions 5 10-31-2010 04:21 AM
