Quadrajet & Timing - Dallas area? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-11-2016, 11:08 AM Thread Starter
komodo's Avatar
Hey Members,
This may be in the wrong section, but I'm looking for a recommendation in the Dallas, Texas area.
I need a name & number to a shop or tuner who can correctly dial in my Qjet and timing on my Pontiac 400.
Frankly, a couple of local speed shops have tried to do it and my engine still runs hot; difficult to start, etc.
Thanks in advance.
Wayne
komodo is offline
post #2 of 5 (permalink) Old 01-11-2016, 11:37 AM
Quoted: 106 Post(s)
Search the group for hot start problems and pump plate clearance.
I have found with mine that to start you have to snap the key quickly to the start position.
You either need to read up on these problems and do it yourself or find an old skool mechanic that is well versed in Pontiacs.
Here is everything you want to know about Q-Jets, I bought the book to rebuild mine.
http://cliffshighperformance.com/sim...orum/index.php
Goat Roper is offline
post #3 of 5 (permalink) Old 01-11-2016, 12:07 PM Thread Starter
komodo's Avatar
Thanks for the reply Goat Roper; I'm trying to find a local Pontiac expert.
komodo is offline
post #4 of 5 (permalink) Old 01-11-2016, 01:52 PM
pjw1967's Avatar
You might want to consider contacting/joining The GTO Assn of N. Texas to see if anyone can help.
GTO Association of North Texas
I cured my '67 running hot and hot start problems with a high torque mini-starter, #2 battery cables, heavy duty Hayden clutch fan, timing set to 9 BTC, and slightly rich mixture. I determined the mixture by downshifting which would cause backfiring thru carb, then opening up the idle mixture screws a half turn and going out again and downshifting. I kept doing this till the backfiring stopped and then opened them up another half turn. Lean will cause motor to run hot. Good luck.
pjw1967 is offline
post #5 of 5 (permalink) Old 01-11-2016, 03:10 PM Thread Starter
komodo's Avatar
pjw1967,
Thank you for sharing the contact and your experience on your own car! That is very helpful.
Much Appreciated!!
komodo is offline
Dallas Area trtownsend 2004-2006 GTO General Discussion 0 04-08-2013 02:08 PM
Dallas area GTO Experts Vetterss Southwest 2 02-19-2011 06:04 PM
Track day in dallas area DementedSix0 Southwest 0 10-23-2010 11:11 PM
Dallas Area Phoenix 2004-2006 GTO General Discussion 9 12-24-2004 12:26 PM
