Question on Exhaust Manifolds - Pontiac GTO Forum
post #1 of 7 (permalink) Old 02-16-2014, 01:47 PM Thread Starter
I have a 68 400 engine (9790071) in my 67 GTO. It had old headers on it that I'm getting rid of and replacing with manifolds. I attached photos. They are the d ports and not the round ports. The engine is standard, not HO or Ram Air. I'm having a hard time finding just standard manifolds through the online part stores. Is there any reason I cant use the HO or Ram Air manifolds provided they are d port and right size? If there isnt, is there any reason why I wouldnt do that vs. trying to find the standard? I'm replacing the entire exhaust system .... Thanks in advance for your feedback!
ID:	34026   Click image for larger version
Kev0477 is offline
post #2 of 7 (permalink) Old 02-16-2014, 02:35 PM
Norms68's Avatar
These guys should have what you want.
Pontiac
-Norm
Norms68 is offline
post #3 of 7 (permalink) Old 02-16-2014, 04:02 PM
Quoted: 98 Post(s)
The standard 'log' manifolds are not reproduced, that I am aware of. They can be sourced used. If I were you, I would upgrade to the HO or Ram Air (same thing) cast iron manifolds, which are a simple bolt on deal. You will need to re-route the battery cable and insulation tube to use these, however. These manifolds require a different head pipe (three studs) than the stock log type 2 stud head pipe. But, because you are installing all new exhaust, this is not an issue. The cast iron HO manifolds flow almost as well as tubing headers, and never leak or rust out. They truly are a worthwhile upgrade.
post #4 of 7 (permalink) Old 02-16-2014, 05:05 PM
68Resto-mod's Avatar
I put RARs on my 68. Bolted right up. No hastle. Headers can be a real PITA.
68Resto-mod is offline
post #5 of 7 (permalink) Old 02-16-2014, 06:36 PM Thread Starter
Thanks for the replies. Seems like from the posts and past threads I could find, most people are very happy with ram air restoration's manifolds. Didnt see many comments about what they offer for the rest of the exaust system. Has anyone heard about the quality of their their full exhaust kits?
Kev0477 is offline
post #6 of 7 (permalink) Old 02-16-2014, 09:39 PM
I've used several of their parts on my car, just not the remainder of the exhaust system. If it helps, in my experience everything they make is really high quality and I wouldn't hesitate to recommend them.
post #7 of 7 (permalink) Old 02-16-2014, 10:47 PM
My son has a set of stock manifolds and a set of RARE manifolds left over from his rebuild on his 68 GTO.
They be d port and available.
Sorry just retread your post, not sure if 68 manifold fit a 67 goat
BTW the RARE manifolds are the OS'd
Bill
bondobill is offline
1965 GTO Ram Air Restorations Exhaust Manifolds - Downpipe Question hooperk 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 06-29-2012 04:35 AM
HO Exhaust Manifolds HANK67 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 03-10-2012 08:01 PM
67 ho exhaust manifolds aftermarket best ones available? fiesta62 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 5 11-19-2011 08:03 AM
exhaust manifolds Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 11-17-2010 11:54 AM
Exhaust Manifolds texasgto 2004-2006 GTO General Discussion 1 02-22-2005 11:36 AM
