Question on Timing (easy I think) - Pontiac GTO Forum
post #1 of 15 (permalink) Old 08-17-2011, 06:29 PM Thread Starter
Quoted: 12 Post(s)
I took the old goat out after sitting in the garage for 5 years and it really runs pretty good. The one problem is that it starts hard when it warms up. I remember turning the distrubitor on way or another to cure this but cant remember. I also remember getting some ping due to the cheap fuel if my memory serves me right Can someone help ?
Thanks Dino
keiko is offline
post #2 of 15 (permalink) Old 08-17-2011, 08:18 PM
When you turn the distributor, you change the timing. Since both symptoms can be fixed by RETARDING the timing, and a Pontiac distributor turns CCW, you must turn it CCW to retard ignition timing. I would use a timing light, and see where you are at now. Retarding the timing might fix the problem....too far will also effect the performance negatively. E
Eric Animal is offline
post #3 of 15 (permalink) Old 08-17-2011, 08:22 PM
Quoted: 23 Post(s)
welcome Dino....if you turn the vacuum advance diaphragm towards the motor you are advancing the timing, sounds like you need to turn it a touch back toward the firewall to retard it, could also be heat sink on the starter and wires down there make sure they are as far away from your exh. manifolds as possible. if its an older build on the motor you will want to run at least 93 and may need to mix in race gas to get to 101 as it will have 10+:1 compression.
Instg8ter is offline
post #4 of 15 (permalink) Old 08-17-2011, 08:30 PM
SOMETHING NOT TO DO: Dont stand the springs on end, under a lift, with a car on it. Let the lift down to compress the spring. Tie the spring with coat hangers. And remove to install in the car......."someone" used to do this in the early 80's......
post #5 of 15 (permalink) Old 08-17-2011, 08:43 PM
Quoted: 98 Post(s)
Eric, I almost never need to remove my coil springs when I adjust my timing. Sometimes, yes, but not often.
post #6 of 15 (permalink) Old 08-17-2011, 08:52 PM
likethat's Avatar
Oops! wrong thread for this response!
67 GTO H.O. Convert 4spd
likethat is offline
post #7 of 15 (permalink) Old 08-17-2011, 08:55 PM
Quoted: 23 Post(s)
almost never
post #8 of 15 (permalink) Old 08-17-2011, 09:12 PM
Will a moderator please move this post to the proper thread....before I start to cry 'cause everyone is teasin' me!!..........
post #9 of 15 (permalink) Old 08-17-2011, 09:14 PM
likethat's Avatar
coat hangers Even!
likethat is offline
post #10 of 15 (permalink) Old 08-17-2011, 09:18 PM
It was all we could afford, back in the "good ol' days"...before the EPA, OSHA, orange cones, and yellow vests with day-Glo stripes were invented....heck I used to ride my bike 200 miles each way in the snow to get to school......... I'm going to bed now....G'night!
easy turbo 350 transmission question virginiavenom 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 06-25-2011 09:49 PM
timing question The Chosen One Service, Maintenance and Technical Discussion 2 06-06-2011 07:52 AM
Timing question 69-JUDGE 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 23 09-05-2010 05:24 PM
timing question 67lemans 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 04-06-2010 08:17 PM
Easy Question Wing_Nut The Lounge 8 11-07-2007 12:08 PM
