RA IV cam and lifter combo - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-18-2011, 01:49 AM Thread Starter
Seol21's Avatar
Hi fellas, I am building a 71 400 with a RA IV cam ( edelbrock 7157) 231 Intake/240 Exhaust. I was thinking of getting rhoads lifters but im not sure if they are worth it. I have a pair of not so great 73 cc heads im using till i find some 6X heads. Anyone have any suggestions? Anyone running this cam and lifter combo? Or what other lifters has anyone used with good results?
Thanks in advance
Seol21 is offline
post #2 of 4 (permalink) Old 10-18-2011, 03:25 PM
Could you tell us more about the car and how you plan to use it? (Trans, gear ratio, etc.)
post #3 of 4 (permalink) Old 10-18-2011, 06:47 PM
Quoted: 100 Post(s)
73cc heads will want 100 octane fuel on a 400 cid engine. Race car?
post #4 of 4 (permalink) Old 10-18-2011, 11:33 PM Thread Starter
Seol21's Avatar
Ill be using a TH400, i think its a stock stall converter for now and 3.90s in the back. Ima be driving the car on weekends and my goal is to have a 12 second car. All i need to be satisfied. The heads are some crappy #11 heads that have had some work done to them. So theyll be ok while i get some better heads. I'm just kinda stuck on the lifter part. I am kinda of a newbie as you can tell, so any advise helps fellas.
64 LeMans by the way. I'll post some pics soon.
Thanks again
Seol21 is offline
lifter adj. mikey gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-16-2011 12:37 AM
Will I need new lifter? lasoya113 Engine Discussions 3 05-25-2011 02:16 AM
Valve lifter pan question Al T 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 09-11-2010 05:56 PM
Jacked up a lifter and cam?? takethegoat 2004-2006 GTO General Discussion 7 08-07-2009 12:17 AM
Valve Lifter Noise Mean Goat Service, Maintenance and Technical Discussion 2 10-18-2005 07:38 PM
