Rebuilding tri power carbs - Pontiac GTO Forum
post #1 of 2 (permalink) Old 04-07-2018, 09:58 AM Thread Starter
Quoted: 162 Post(s)
I am in the process of rebuilding my tri power carbs and started with the front carb (two outer are the same as you all know).
I disassembled the carb and soaked it in parts cleaner for ~30 minutes. Then washed with really hot water, used an air gun to blow out. I then cleaned the top two pieces off (appeared to be a film / paint) and re-dipped in the parts cleaner for another 30 minutes and repeated the cleaning and drying process.
Now the carb was ready for rebuilding, but first I wanted to protect the metal. I taped off pieces I did not want painted and then sprayed the iron base with two light coats of grey primer followed by two light coats of semi gloss black. The top two pieces of the car (body and lid) were lightly painted with Eastwood's Carb Renew II Bronze.
I am happy so far with how they look, but have a question about the throttle blades - they look rusted / discolored. Should I treat them with anything ? I know nobody will see them but me, but still now would be the time to correct....
Name:	front carb throttle blades.jpg
ID:	108066   Click image for larger version
Name:	front carb internal.jpg
ID:	108074   Click image for larger version
ID:	108082   Click image for larger version
Name:	front carb 2.jpg
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #2 of 2 (permalink) Old 04-08-2018, 09:40 AM Thread Starter
Quoted: 162 Post(s)
Well I did not change the blades or clean them with anything. They appeared to be sealing fairly tight (I could see a sliver of light around one of the blades when holding up to the light) and given that each has an intentional pinhole I figure they are fine. Car fired right up and the accelerator squirt was super strong. Now for the next two....
BTW - John @ Pontiac Tripower is a great guy if you need anything for your Pontiac. I bought the carb rebuild kit and bolt package from him. Everything was neatly packaged and labeled to ease installation. And of course if you have questions, he is readily available and very knowledgeable.
Current setup:
4 speed Muncie
cij911 is offline
Tri power carbs jaloi 1964-1974 Tempest, Lemans & GTO General Discussion 5 09-30-2014 09:12 AM
Tri Power Carbs restoration xconcepts 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 15 07-05-2014 01:35 PM
66 GTO Tri-power Manifold w/ carbs vrusso1096 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 11-17-2012 03:47 PM
66 GTO Tri-power Manifold w/ carbs vrusso1096 1964-1974 Tempest, Lemans & GTO General Discussion 0 11-17-2012 02:04 AM
