Rochester Carb rods - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-07-2018, 11:08 PM Thread Starter
Rochester Carb rods
Hi... while collecting Rochester rods I have found two types. For instance I have a 42 and a 42B...then a 43 and 43B..44 and 44B..you get it. The B rods are definitely tapered differently being fatter off idle then quickly tapering at mid rod while a standard rod has a uniform taper along the length. Does anyone know why the difference and what the application may have been for?
Dave N Laura Chomyn is offline
post #2 of 5 (permalink) Old 07-11-2018, 01:43 PM Thread Starter
I finally found some info... looks like the B is a high performance 0.026 tip rod...but so is the 43...M would designate truck use for better mileage it has a 0.036 tip
post #3 of 5 (permalink) Old 07-11-2018, 11:35 PM
Hang on to those... the variety of available rods has just about dried up. The only source I know of that has any selection at all is Cliff Ruggles, and he machines them himself.
post #4 of 5 (permalink) Old 07-12-2018, 11:37 AM Thread Starter
Thanks...discovered that already and I happened to luck out and find someone with a treasure trove..but he is getting reluctant to sell as well!!
post #5 of 5 (permalink) Old 07-12-2018, 11:38 AM Thread Starter
As well.. my car runs much better on the B rods but I am having trouble with a rich idle so that probably makes sense judging by the shape of the tip.
1967 GTO Rochester QJet Fuel Line from Pump to Carb size 3rd1967gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 11-27-2016 06:49 AM
Q jet carb vs holly carb??? mbspeed 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 08-07-2013 06:51 PM
Cold start problems with rochester quadrajet. Fuel draining out of carb ? dillon14 1964-1974 Tempest, Lemans & GTO General Discussion 8 07-15-2011 10:55 PM
Which Rochester Carb do I have? Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 01-09-2011 12:52 PM
