Running a built 421, 65 GTO, Tri-power, considering a 66 Tri-power setup - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-24-2017, 10:50 AM Thread Starter
avman's Avatar
Quoted: 5 Post(s)
My wife's 65 GTO is running a built 421 and I am considering moving from the smaller center carb 64/65 setup to a 66 for the larger center carb/more power. The carb setup on her motor MUST be a Tri-power, so it seems the only move up in performance would be to go to the 66 Tri-power setup. Can you give us suggestions on sources for the 66 manifold, center carb, and a "tuner" who could take the manifold and carbs and modify them for the best performance? I can provide specs on the roller cam, CR, rear gear (yet to be determined, but likely a 3.75 or 3.90) etc.
Thanks!
avman is offline
post #2 of 5 (permalink) Old 11-24-2017, 10:53 AM Thread Starter
avman's Avatar
Quoted: 5 Post(s)
If the Tri-power setup we have can be modded or tuned to support mid 400s horsepower, that's OK too, but I need info on tuning/performance enhancing capabilities as well. Thanks
avman is offline
post #3 of 5 (permalink) Old 11-24-2017, 04:01 PM
Quoted: 54 Post(s)
Welcome to Pontiac Tripower | Pontiac Tripower
"...The shop owner is a Pontiac nut! For this reason...Call to discuss your Pontiac multi-carburetion needs..."
http://www.thecarburetorshop.com/Mul...m#Factoryunits
http://www.thecarburetorshop.com/Pon...emanifolds.htm
bigD is offline
post #4 of 5 (permalink) Old 11-24-2017, 08:47 PM Thread Starter
avman's Avatar
Quoted: 5 Post(s)
Thanks! I will look into it and contact them. Anyone else?
avman is offline
post #5 of 5 (permalink) Old 07-28-2018, 10:46 AM Thread Starter
avman's Avatar
Quoted: 5 Post(s)
All American Carburetors
All American Carburetors has the 3 Rochester carbs from the 65 Tripower now. From referrals and carbs I have seen them do in person, and conversations with them I am confident that they will do a great job. They emphasize that they restore, not just rebuild them. I also sent the cam and other build specs to them so they can get an idea of what to do (jetting, etc) to maximize the build for her motor.
avman is offline
66 tri power setup?! Chris-Austria 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 01-28-2011 01:30 PM
found 421 tri power, worth install? auburnconsulting 1964-1974 Tempest, Lemans & GTO General Discussion 6 11-12-2008 02:59 PM
