searching for HP - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-11-2018, 04:29 AM Thread Starter
searching for HP
Hi Guys. I appreciate the knowledge passed on to me so far. ( sorry past Chevy guy) I have a recent purchased 1970 GTO 455 HO with a 1974 455 block with the original 1970 6 4 455 87cc heads, automatic transmission. The stock cam is 273/289 duration cam .410 plus or minus.011 lift. My plan is to replace the cam close to the stock manual trans cam of 288/302 duration lift.414 plus or minus .011 with an comp cam .292/303 cam with .516 lift.. also Edelbrock performer intake, Pypes RA 2 1/2exhaust manifold, Holley double pumper carb. 750 or 800 cfm. I was born in 1959 and this is I agree how I thought in the day, former auto mechanic now jet builder. I'm open for opinions. :-) Recent evaluation in my opinion says the bottom end is sound as compression test results were 158 to 165 psi or I would consider doing more. Thanks
slider98208 is offline
post #2 of 3 (permalink) Old 02-11-2018, 11:09 AM
Quoted: 347 Post(s)
When searching for HP, I generally look under the bed or in that kitchen draw that has "stuff" in it that you don't want to chuck out, but might use, along with the rounded off tipped phillips screw driver, sloppy pliers, dull razor knife, and flashlight that doesn't work.
Looks like you have about 9.5:1 compression with your heads and have selected the Comp Cams 041H cam.
I could not find if the .516" lift is with 1.5 ratio rockers or the 1.65 ratio? Several things come to mind. Are you pulling your heads or doing this with heads on? With the .516" lift, you may or may not need to open up the pushrod holes at the top of the cylinders where the pushrods go through - there are 4 of them that are round holes. With a higher lift cam as this one, the pushrod can hit/bind/bend on the side of the hole at maximum lift - more so with the 1.65 rockers.
"I did that once. I didn't elongate the pushrod holes and ran 1:65 rockers. I used the Harland Sharp setup. I wish I did elongate the holes because I wound up bending some pushrods. Had to replace the pushrods plus spend another x amount on gaskets after pulling the heads off, plus all the labor once again. I wouldn't recommend doing it on the engine as metal in the oil basically can destroy an engine. You only have to lay the holes back approx. 1/8" or so about 3/4" down to get rid of the material. It's not hard at all just takes a bit of time depending on how "sharp" your burr is."
With that cam, you will lose some bottom end power. Often recommended with the 041 cam in a 455 is the Rhoades Lifter. You can get these with the Super Groove Lube which can help in cam lobe oiling. Used the Original Rhoades Lifters (no Super Groove) in my brother's 360 Mopar build, 9.5 compression, 284 duration cam, .491" lift. The engine idles like a stocker, good vacuum to operate the power brakes, and pulls hard. I can't really hear the lifter noise that most seem to mention unless the hood is raised and I put my head near the rocker covers - sounds like solids. It has been several years since I rebuilt it and I think he has about 20K on the engine. You can read more here: Products
With the higher lift, you will want to use matching springs - possibly retainers depending on your source on the valve springs. You will note that CC states the heads must be cut for their springs, probably to get the correct installed height. The RA IV heads used a taller valve for the higher lift cam. Not sure what the 455HO heads used, so you want to make sure that you have the proper clearance between the spring coils at full lift as well as the bottom of the spring retainer to the top of the valve guide. Again, you can get spring retainers that are taller then stock that could eliminate any need for head machining and give you plenty of clearances. So this needs to be checked.
You may also want to opt for better/stronger pushrods so you minimize deflection on the higher lift.
I would not personally use the Holley double pumper on the street unless you have some 3.90 - 4.33 gears. Pontiacs are heavy cars. A vacuum secondary is the way to go. Best investment is the factory Q-jet manifold and Q-jet. Save your money on the Edelbrock and spend it on a rebuilt Q-jet.
Exhaust system is right on.
You will need the long slot rocker arms. If you go aftermarket you won't have any problem as they seem to all be long slot. If the short slot rockers are used, you will bind the rockers up at higher lifts and bend/break things.
Change out the bottle neck 3/8" screw-in rocker arm studs to Chevy Big Block 7/16" rocker Arm studs or you can snap them off with the higher lifts. I used the ARP brand. This will also require you to use some form of Poly lock as the factory type lock nuts will back off. The poly locks are positive locking and won't back off. Now if you use the poly locks, I am not sure how they would adjust with the Rhoades Lifters, but they do have a set that get adjusted just like solids, so this might be the way to go if you use them. You can check around on the FAQ sections which might answer that one.
I think that should cover it, but may have missed something......oh wait, its in the draw next to the loaf of bread twisty ties.
Name:	Long slot rocker arm.jpg
post #3 of 3 (permalink) Old 02-11-2018, 11:21 AM
Quoted: 54 Post(s)
Opinions differ, as you'll see.
The stock iron intake and a properly rebuilt Q-jet will work better than a Performer intake & Holley carb, on the street 455.
Because of the compression of your engine, you'll need to add some octane booster, such as Torco Accelerator, or mix in some race gas, in order to up the octane rating.
As for the cam, I'd go by the duration @ .050 lift numbers, more than the adv dur numbers.
230 dur @ .050 lift is plenty for the intake lobe of a street 455.
The Summit 2802 is a real popular & cheap 455 cam.
The Crower 60243 is slightly bigger. And a Pontiac 041 clone, such as the Melling SPC-8, has been very popular, for many years.
These cams will all require stronger valve springs, which could possibly cause problems, or even valve failure of the 40+ year old 2-piece factory valves.
If you just wanna go slightly larger than the factory 068 cam, there is the Summit 2801, the Lunati version of the RA3 cam, and the Lunati 10510312. Should be able to get by with slightly stronger than stock springs, such as the CC 988-16 springs.
https://www.summitracing.com/parts/sum-2801
Factory Performance Hydraulic Flat Tappet Cam - Pontiac V8 301/313 - Lunati Power
Street Master Hydraulic Flat Tappet Cam - Pontiac V8 276/286 - Lunati Power
https://www.ebay.com/itm/Comp-Cams-9...38.m2548.l4275
Obviously, if you wanna put a lot of money into the heads, you can go with one piece, longer than stock, Ferrea stainless valves, new guides, stronger springs, 1.65 rockers, 7/16 studs, etc, built for over .500 lift cams. Most say that it will cost between $800 & $1000 to have all this done by somebody who really knows what they're doing. But, it's your car & your money. Spend it if you have it !
bigD is online now
Searching for a GTO '67 jefhennie Member Introductions 1 05-26-2015 05:39 PM
searching 4 44070dart 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-15-2012 09:36 PM
how would I go about searching for old GTO? 65hunter 2004-2006 GTO General Discussion 4 02-11-2005 10:31 PM
