Secondary carbs on tripower - Pontiac GTO Forum
post #1 of 18 (permalink) Old 07-10-2016, 04:40 PM Thread Starter
gtoguy389's Avatar
I am having a problem with the rear carb with excess fuel running into the bores. I originally thought it was a problem with the float, but that looks really good with no leaks. I submerged it for several minutes in water, about 20, when I released it, it came right back up to the surface, and no water was inside when I shook it.
Next I checked for pump discharge leakage. There was a small gasket between the venturi cluster and difuser, (synchromesh), but no gasket between that and the screw head. So I placed a gasket there.
That only leaves the needle and seat.
This had been a problem up until 3 years ago when I pulled the entire intake set-up off and ran the Carter AFB. 2 years ago I rebuilt the carbs and checked everything out with a fine tooth comb. So it has been sitting on the bench for the last couple years until a month ago when I decided it was time to reinstall it. When I put fuel to the carb it looked like a faucet running.
Even though the needle and seat and gaskets were new. Is this just from sitting and need a new needle and seat, or is there a bigger underlying problem that I am not picking up on? Thank you for any help.
gtoguy389 is offline
post #2 of 18 (permalink) Old 07-10-2016, 10:16 PM
Quoted: 98 Post(s)
I have been running tripowers since the '70's, and have had good results using the old all brass needles without the rubber tip. I think the new alcohol-tainted fuels can hurt the rubber tip and the accelerator pump cup. My buddy has replaced two cups in his tripower car in the past 6 months.....I haven't worked on my '65 tripower's carbs in about 30 years, but they have brass needles and leather cup seals. I think you have a needle/seat problem, or the float is physically bent and hanging open against the side of the bowl, etc, keeping the needle/seat open. These are simple carbs, and, once set with original quality parts, are really bulletproof. Don't overthink it. Check the float, and needle/seat. Good luck.
post #3 of 18 (permalink) Old 07-11-2016, 08:43 AM Thread Starter
gtoguy389's Avatar
Thanks Geeteeohguy, I placed the airhorn back on the body, and turned the carb back and forth. I can here the float moving freely opening and closing the needle. I have been researching the needle and seats, and see a new style from Daytona Carburetor. Have you heard anything about these and how they might work?
post #4 of 18 (permalink) Old 07-11-2016, 02:59 PM
Quoted: 98 Post(s)
Nope.
post #5 of 18 (permalink) Old 07-12-2016, 01:06 PM
chuckha62's Avatar
Quoted: 18 Post(s)
What are you running for a fuel pump? The original A/C Delco fuel pump was calibrated to supply only 4-5 psi. Aftermarket pumps routinely supply in excess of 7 psi, which is enough to unseat the needle from the seat in some carbs. It could affect one carb and not another in your tri-power set up.
chuckha62 is offline
post #6 of 18 (permalink) Old 07-13-2016, 08:53 AM Thread Starter
gtoguy389's Avatar
I've got an older AC-Delco fuel pump, believe I purchased it from Ames many years ago.
post #7 of 18 (permalink) Old 07-13-2016, 11:40 AM
chuckha62's Avatar
Quoted: 18 Post(s)
You should be fine for fuel pressure. I'd look at the neoprene tip on the needle and see if it's damaged. Or just replace it.
post #8 of 18 (permalink) Old 07-13-2016, 01:01 PM Thread Starter
gtoguy389's Avatar
After looking closely at the rubber needle tip, there is one little spot that just doesn't look right. It does not look like enough to be a problem with the naked eye, but I just ordered a new needle and seat assembly from Daytona Parts. Hopefully this will fix the problem.
post #9 of 18 (permalink) Old 07-14-2016, 10:48 PM
Make sure the throttle plates on both end carbs are closing completely - 100% - if even a little air is leaking past them at idle, you'll have problems. GM had a special epoxy sealer they sometimes applied to the plates to make sure they sealed shut at idle.
post #10 of 18 (permalink) Old 07-15-2016, 10:00 AM Thread Starter
gtoguy389's Avatar
Thanks Bear. When I had the Carbs up on the bench I did a lot of work to ensure they were closed completely. The Daytona valves came today, hopefully by Sunday I will have time to work on them again.
66 Tripower Carbs PontiacPaul 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 12-22-2014 09:02 PM
2 G carbs. Fathead Racing 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 15 08-20-2014 11:51 PM
Holley 750 Double Pumper or Vacum secondary??? deze2000 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-30-2009 03:39 PM
Jetting and secondary spring selection Bensjammin66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 07-16-2009 12:25 PM
Carbs? GoToIt 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 09-29-2004 10:02 AM
