Source for factory appearing tall style valve covers - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-06-2018, 02:46 PM Thread Starter
Quoted: 17 Post(s)
Guys
Finishing up the assembly of my 400 and just realized the OEM valve covers won’t fit over the roller rockers. I’m looking to source new valve covers but can’t find ones with a factory appearance, i.e. simple chrome ones with the breather holes i. The middle. Does anyone make these?
70conv is offline
post #2 of 8 (permalink) Old 10-06-2018, 03:59 PM
There are aluminum spacers available in different heights, OPG has some, and I have seen others on ebay also. I have a 70 RAlll motor in my 65, I used oversized cork gaskets to clear the early style factory valve covers that were run through 66. I'm not running roller rockers though.
1965 GTO Convertible
1965 Mid-Engine Corvair
1967 Cutlass Supreme convert, LS3
1970 El Camino SS 396
2005 Chevrolet Duramax pick up
2006 GTO 6M
2011 Honda Accord 6 speed Navi Coupe
2014 Harley Davidson Ultra Limited
19sixty5 is offline
post #3 of 8 (permalink) Old 10-06-2018, 05:32 PM
Quoted: 54 Post(s)
Some use the 5/16" thick gaskets. If that's not tall enuff, you can glue 'em together & run as many as needed.
https://butlerperformance.com/i-2445...spm-11765.html
https://www.summitracing.com/parts/e...saAtOTEALw_wcB
bigD is online now
post #4 of 8 (permalink) Old 10-06-2018, 08:18 PM
Quoted: 33 Post(s)
The Edlebrock 5/16" thick work with the roller rockers.
tjs72goat is offline
post #5 of 8 (permalink) Old 10-06-2018, 08:27 PM
I use a set of these with stock factory chrome valve covers. Combined with a set of thick cork gaskets both above and below the spacer, they clear roller rockers AND Jomar stud girdles.
Pontiac Spacers [Black]
I painted mine engine color, gaskets and all. The casual observer will tend not to notice them.
post #6 of 8 (permalink) Old 10-06-2018, 08:39 PM
Quoted: 33 Post(s)
If you have AC, you can't go too big or your bracket won't fit over the top of valve cover.
post #7 of 8 (permalink) Old 10-07-2018, 11:17 AM
Oh yeah, thanks for remembering that and pointing it out. My car had factory A/C but I opted not to use it over concerns about low manifold vacuum - but you're right, that could be a problem. None of the manifolds I've been ("forced to") use have the bolt boss for that bracket. I'm sure it would have to be modified some to clear with the spacers, or maybe even a new one fabricated.
post #8 of 8 (permalink) Old 10-07-2018, 04:02 PM
more on stock valve covers clearing roller rockers
Originally Posted by 70conv View Post
Guys
Finishing up the assembly of my 400 and just realized the OEM valve covers wonít fit over the roller rockers. Iím looking to source new valve covers but canít find ones with a factory appearance, i.e. simple chrome ones with the breather holes i. The middle. Does anyone make these?
i glued two 1/4 in cork gaskets together then glued them to my stock 400 painted tin valve covers. they clear harland sharpe 1:65 roller rockers with .575 intake and .590 exhaust gross lift. i heavily grease the head side of the gaskets when installing. i have used the same valve covers with the same gaskets for probably 15 years. they do not leak, they come off in an instant, are easy to reinstall and are indefinitely reusable. i do use spreader bars for the valve cover bolts. be sure you straighten the valve cover gasket flanges before gluing on the gaskets. also do not over tighten the valve cover bolts. if you need to take valve covers off frequently, this approach works. and you have stock valve covers on your bigger cam/rocker motor. good luck
john23 is offline
aluminium radiator factory style which one is best fiesta62 1964-1974 Tempest, Lemans & GTO General Discussion 3 12-21-2012 06:56 PM
"Check oil" message keeps appearing... ImpulseBlue06 Service, Maintenance and Technical Discussion 3 05-18-2012 09:42 AM
Odd "oily" pattern appearing on front of car RunksGoat 2004-2006 GTO General Discussion 9 12-30-2010 09:21 AM
Paint Chips - Rust is appearing! What process is necessary? O'Town Exterior Discussions 3 01-17-2007 02:54 PM
Tall guys Vs. GTO seats SilverZiege 2004-2006 GTO General Discussion 13 11-16-2004 10:37 AM
