Spark wire length - '65 389 - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-08-2017, 06:10 PM Thread Starter
Roqetman's Avatar
Quoted: 16 Post(s)
I'm going put new spark plug wires on my GTO, the old have a couple couple cuts and are way too long. It has GM HEI distributor and I want the wires to go behind the heads to the plugs instead of over the valve covers. Does anyone know what length each wire should be and will this a cut to fit application or... is there a brand/part number for 8 mm wires that are a custom fit?
Also, does anyone know the diameter of the stock harmonic balancer (where the timing marks are)? I want to put on timing tape and do not have calipers large enough to get a good measurement.
Thanks, Roqetman.
Roqetman is offline
post #2 of 3 (permalink) Old 03-12-2017, 11:50 PM
Thanks, Roqetman.
you might try Jacobs wires...they come way long and you cut to fit...they also come in 8 mm...i've had mine for years and zero issues...good luck...
john23 is offline
post #3 of 3 (permalink) Old 03-13-2017, 12:25 PM Thread Starter
Roqetman's Avatar
Quoted: 16 Post(s)
I'll check them out. Thanks!
Roqetman is offline
69 Spark plus wire looms dan woodland 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 09-24-2015 12:59 PM
44s ac delco spark plugs for 389 '66 gto PONTIAC CLASS 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 02-06-2014 06:39 PM
Spark Plug Wire Looms DanC 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-22-2013 09:07 PM
Spark Plugs/Wire help Fama Goat 2004-2006 GTO General Discussion 10 11-30-2011 03:55 PM
Clutch rod length Rukee 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 12-04-2007 11:12 AM
