Still think Pontiacs can't make power? - Pontiac GTO Forum
post #1 of 12 (permalink) Old 10-29-2015, 07:42 AM Thread Starter
If you do, you're mistaken.
Check THIS out!
Let me give you a little teaser from the article:
Semco Performance brought a 465ci Pontiac engine to the AMSOIL Engine Masters Challenge to go head-to-head with the bigger Fords and Chevys in the big-block class and took home the win by churning out more than 700 hp.
Pontiac Takes The Win at 2015 Engine Masters Challenge
I just love the smell of baked bow-tie in the morning....
post #2 of 12 (permalink) Old 10-29-2015, 09:26 AM
post #3 of 12 (permalink) Old 10-29-2015, 12:24 PM
Quoted: 106 Post(s)
Check THIS out!
With that much HP you can bend the frame and if you bend the frame the car won't run right.
Name:	Chevy shoes.jpg
Goat Roper is offline
post #4 of 12 (permalink) Old 10-29-2015, 12:29 PM
Quoted: 98 Post(s)
Where's Alky when we need him?
post #5 of 12 (permalink) Old 10-29-2015, 12:32 PM
Quoted: 98 Post(s)
So does this mean Pontiac is a big block?
post #6 of 12 (permalink) Old 10-29-2015, 01:50 PM
Right here.....biting my lip
Seriously I love the engine masters challenge and I think its awesome when any of the "off brands" wins one. I think its great that people are still finding ways to extract more power out of these "obsolete" engine designs.
post #7 of 12 (permalink) Old 10-29-2015, 02:14 PM
Other motors made more HP, so it must be HP per CI?
post #8 of 12 (permalink) Old 10-29-2015, 04:02 PM
Quoted: 98 Post(s)
Rukee, yes, I think so. The Poncho was the only one under 500 cid.
post #9 of 12 (permalink) Old 10-29-2015, 06:08 PM
Quoted: 361 Post(s)
Rules say "Normally aspirated domestic V8 production passenger car big block engine types only. Pontiac, AMC, Oldsmobile, Cadillac Pontiac, Buick, Ford FE, Ford 385 series including Boss 429, Chevrolet big block including 10.2-inch deck blocks and W Series, Chrysler B and RB Wedge permitted. Chrysler Hemi engine prohibited."
DISPLACEMENT
Minimum displacement 450 cubic inches. Maximum displacement unlimited. Cubic inch is calculated by bore x bore x stroke x 6.2832.
ENGINE BLOCK
Any domestic OEM passenger car block of an eligible engine type, or commercially available cast iron or cast aluminum aftermarket OEM replacement engine block permitted. Engine block must retain OEM cylinder bore spacing and OEM block angle.
NOTE: This class WILL use a cubic inch divider in scoring to
compensate for varied engine displacement. Scored test rpm range
3000-7000 rpm.
So, the Pontiac engine produced the most HP per CI as factored against the other engines. Other engines made more HP, but they also had more cubes to get there. Cubic inches rule, but a Pontiac engine has proven that it can pull the most HP per CI out of a single carbed engine. Isn't that called "efficient?" I call it PERFECT.
post #10 of 12 (permalink) Old 10-30-2015, 01:18 PM
Quoted: 98 Post(s)
Long live the obsolete Strato-Streak V8, and the obsolete fossils who pilot them down the road!!!
Did Pontiac Make a Tri Power 400 in '69? Goat Roper 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 05-05-2015 06:15 PM
Thinking about trying to make more power. ballinboyz44 Engine Discussions 6 02-24-2011 06:46 PM
How much power will i make GTOMOE9 Engine Discussions 10 07-19-2010 09:04 PM
Power Windows, Power Locks, Seat Belts, Power Rear View Mirror, Back Speaker Location GQUINCOCES 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 01-03-2009 07:18 PM
