Strange idle issue. Slows down and speeds up by itself - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-17-2017, 01:09 AM Thread Starter
I'm working on a 66 GTO for a guy. It has a fresh rebuild of 428 Pontiac engine Edelbrock performer intake, Holley 800 spread bore double pumper carb. MSD mechanical advance distributor. It has Comp XE274H Hydraulic flat tapper cam.
It speeds up and slows down by itself. Here is a video of it running. What can cause this condition? I tried blocking the PCV off and it still does it.
Danford1
danford1 is offline
post #2 of 4 (permalink) Old 01-17-2017, 07:44 AM
Vacuum issue? Mine did the same after carb adjustments and a misplaced vacuum line was discovered as the issue.
post #3 of 4 (permalink) Old 01-19-2017, 08:12 PM
Quoted: 347 Post(s)
It is possible that the carb is actually running lean on that engine. Just for fun, after checking all the vacuum lines as noted, back the idle screws out to fatten up the carb and see if it changes.
Try those things and get back with us.
post #4 of 4 (permalink) Old 01-30-2017, 07:40 PM
Quoted: 98 Post(s)
X2. Usually a surge at idle is due to an excessively lean condition. Vacuum leak or carb adjustment. See if it speeds up and smooths out if you drizzle a little carb cleaner into the carb or as stated, restrict the intake with your hand slightly.
grinding noise at low speeds and humming at cruising speeds sutherlacd27 2004-2006 GTO General Discussion 10 09-30-2010 08:59 AM
Fast Idle Issue daveh70 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 08-23-2009 09:25 AM
Another strange door lock issue macgto7004 Interior Discussions 9 05-02-2008 06:37 AM
Strange issue with Flat tire at Dealership. GTOtbird Service, Maintenance and Technical Discussion 7 12-30-2006 01:22 PM
strange temp gauge issue Tower Service, Maintenance and Technical Discussion 12 11-21-2006 10:14 AM
