Stupid Timing Question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-12-2018, 02:47 PM Thread Starter
I have a Frankenstein 400 4bbl where the block is from a 69, the heads are 73 and various other parts in differing years. What should the timing be set to? Looking at the specs from 69 thru 73, some years calls for different timing amounts (for example, 69 shows 9 degrees, 71 jumps to 12 and then in 73 it is up to 13). Appreciate any guidance. Thanks
bkellis1 is offline
post #2 of 3 (permalink) Old 10-12-2018, 02:50 PM Thread Starter
BTW - I did read the sticky and it says to start with 16. Just wondering about the different specs called for by the various years, and which component of the motor (block, heads, etc) would dictate which to use. I'm guessing it would be the block, but looking for others thoughts. Thanks
bkellis1 is offline
post #3 of 3 (permalink) Old 10-12-2018, 03:54 PM
Quoted: 98 Post(s)
Blocks are all the same, as are the pistons, originally. Pontiac changed compression ratios with heads. Spec for my '65 and '67 GTO's is 6 degrees BTDC initial. Later GTO's, about 9 degrees. I'd start out at about 8 to 10 and see if it'll run without detonation. 16 degrees initial is too far advanced and will give your starter a workout.
1968 GTO set base timing and total timing?? rob40999 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 15 05-27-2018 07:37 AM
Stupid question kwiktsi 2004-2006 GTO General Discussion 10 04-10-2006 12:23 PM
stupid tires question...need QUICK awnser DK2F Wheels and tires 17 04-10-2006 01:35 AM
Stupid question i can't seem to get a straight answer to CrabhartLSX Drive train, suspension, alignment and brakes. 7 03-03-2006 10:32 PM
