tach wiring - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-12-2018, 02:19 PM Thread Starter
tach wiring
I have a rally tach for my 65 GTO and am stuck on the wiring. It's the kind with two terminals. One has an "+" and the other one is unmarked. Does one side go to the neg coil side and the other the battery side? Thats how it is now and the gage doesnt work. When I turn the key in the on position the tach just flings forwards and comes right back to zero and stays there. Please help.
ucaddoc is offline
post #2 of 4 (permalink) Old 02-12-2018, 05:10 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
If it's a Factory Tach 2 terminals should be for TI
Standard Ignition Tach has one terminal/ Brown lead to Neg side of coil.
Hopefully you didn't fry it.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 4 (permalink) Old 02-13-2018, 09:05 AM
spuzzy's Avatar
Here's a tach wiring diagram for a 64. Should be similar to what you are looking at.
spuzzy is offline
post #4 of 4 (permalink) Old 02-13-2018, 02:17 PM Thread Starter
I have the Summit racing distributor (Pontiac V8 RTR) and the negative side of the coil is hot? It is an HEI "type" distributor electronic ignition but it is not an HEI distributor.
ucaddoc is offline
In Dash Tach Wiring Roqetman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 09-21-2017 10:18 AM
64 Tach Wiring Routing Question Al T 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 03-15-2015 05:31 PM
64 tach wiring instructions spuzzy 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 01-04-2015 03:52 PM
wiring diagram for tach in a 64 GTO Dhalpern 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-23-2014 04:09 PM
64 Tach Wiring Question Al T 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 07-30-2010 12:46 PM
