Are these stock pistons? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-30-2017, 10:59 PM Thread Starter
Joe Skelly's Avatar
So after tearing down the motor, I noticed that the pistons have numbers stamped in them. They all have "1956PX .030" stamped into them.
When I tried looking for replacement pistons, I can't seem to find any that have the valve reliefs that look like mine.
Are these OEM?
Name:	P2.1 ID Number Small.jpg
1966 Lemans w/ 1965 GTO 389 Motor
Joe Skelly is offline
post #2 of 3 (permalink) Old 09-30-2017, 11:57 PM
The pistons are old 389 .030 Sealed Power forged pistons, forged replacements from the '70's-80's.
post #3 of 3 (permalink) Old 10-01-2017, 09:01 AM
Quoted: 347 Post(s)
They are the old TRW forged pistons. 1959-1965 389CI. 10.25 compression. .030" over. The one in the picture is .040" over.
Now owned by Federal Mogul. You want to have the bores checked before ordering a new set of pistons if that is your goal. It may clean up and you can go with .030" over as you have. If not, don't go any more than needed and see if the .040" will work. I went .040" over on one of my engines as it was already .030". This leaves you more material and another rebuild should you need to go .060" over. Butler offers the Federal Mogul brand for the 389CI as well as other piston options. http://butlerperformance.com/i-24453...66-389cid.html
Build the engine/compression based on the available gas octane in your area. If you plan on running high octane racing gas, 10.25 compression will work. If you plan on running 91-93 pump octane, keep the compression between 9.0-9.5 with 9.0 being the better number. Match the cam to the lower compression and you will still have plenty of power.
You can email Butler for a recommendation on piston and cam selection so as they match.
Name:	TRW 389 Forged Piston.jpg
2004 GTO Stock Pistons Stitt_Taylor Engine Discussions 0 01-09-2016 09:30 PM
Keep these pistons or toss them? jhogan2424 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-28-2011 07:57 AM
Installing Pistons Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 10 01-11-2011 11:08 AM
Can '670' Heads work on a 1966 389 engine with stock pistons? Ozzie 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 12-27-2009 12:08 PM
some good pistons jradke123 Engine Discussions 9 07-02-2008 12:28 PM
