Timing kit question - Pontiac GTO Forum
post #1 of 9 (permalink) Old 01-16-2014, 05:15 AM Thread Starter
Stickyfingersfrank's Avatar
Timing kit question
Hi
I own a 73 lemans with a 350 engine that i'm going to give a tune up because i've got some oil leaks from the rear seal and the front seal and the oil pan.
The distributor needs some attention too because of pinging in high revs.
So i'm pulling the engine and giving it a paintjob/tune up.
Because i live in holland parts are a little bit harder to come by i already have a full gasket set, distributer kit and enamel for the engine.
Now somebody here in holland has a timing chain kit on craigslist, a comp cams 2112 double roller.
Does this fit a stock engine with stock cam/crank?
Thanx
Frank
Stickyfingersfrank is offline
post #2 of 9 (permalink) Old 01-16-2014, 11:12 AM
I'm pretty sure that set will fit your engine.
You can contact Compcams online and live-chat with a technican.
COMP CamsŪ - Technical Support and Contact Page
Chris-Austria is offline
post #3 of 9 (permalink) Old 01-16-2014, 12:31 PM Thread Starter
Thanks i'll try that, they should know, right?
post #4 of 9 (permalink) Old 01-16-2014, 05:26 PM
I would be very surprised if it doesn't fit. They say "Ideal for mild street performance applications" and "Pontiac 265-455"
If you are building a performance engine I would consider another kit from Comps like the 3112 or 7112. I live in Austria and often order parts from Summitracing. The 2112 will be about 80 Euro to your location including shipping and taxes.
post #5 of 9 (permalink) Old 01-17-2014, 01:49 AM Thread Starter
Thanks i tried to ask it but the online chat at comp cams didnt work yesterday so i sent an email to summit..
Some guy here in holland has it and he want to sell it to me for 45 euro.
I'm going to give my engine a tune up and its a street engine so its stock. But because the most timings kits look like they have a different camshaft sprocket i wasnt shure
And if i select stock replacement on summit its not in the list
So i think i'l give it a try
Frank
post #6 of 9 (permalink) Old 01-17-2014, 07:01 AM
Summit also has a live-chat. You will have to wait until 3pm our time... they start to work at 9am in Ohio which equals 15:00 over here
I'm sure all the kits fit (2112, 3112, 7112) but I cannot tell you which one is best for your application.
post #7 of 9 (permalink) Old 01-17-2014, 07:16 AM Thread Starter
Hmm i thought that the stock camshaft sprocket is just one bolt in the center of the sprocket and not like the one from comp cam with 3 bolts..
If you understand what i mean?
I can't send you a picture now but when i'm home i will post a pic ok?
post #8 of 9 (permalink) Old 01-17-2014, 08:26 AM
The stock kit has only one keyway crank sprocket. The difference to the CompCams kit is the "4-degree incremental adjustability". That's why the 2112 has a 3 keyway crank sprocket.
It will not have an effect in terms of fittment, but it will give you more adjustability. You can retard or advance the camshaft by 4°. (or install it to stock specifications)
post #9 of 9 (permalink) Old 01-17-2014, 09:07 AM Thread Starter
So i had contact with summit live chat..
He also said it would fit!
But you never guess the guy who had it for sale already sold it to somebody else...
So i ordered one on ebay from a guy in england
Thanx for the advice!
Question on Timing (easy I think) keiko 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 14 08-22-2011 12:29 PM
timing question The Chosen One Service, Maintenance and Technical Discussion 2 06-06-2011 07:52 AM
Timing question 69-JUDGE 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 23 09-05-2010 05:24 PM
timing question 67lemans 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 04-06-2010 08:17 PM
new timing light new question 70gto 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 3 04-27-2008 11:23 AM
