Timing Light Opinions/Reccomendations - Pontiac GTO Forum
post #1 of 17 (permalink) Old 01-11-2016, 08:41 PM Thread Starter
Quoted: 106 Post(s)
I am looking to buy a new timing light and running points I also want one with dwell.
I am looking at this one @ Summit, any of you gurus own this or have any other recommendations?
Innova Pro Timing Lights 5568 - Free Shipping on Orders Over $99 at Summit Racing
Thanks,
Goat Roper
Goat Roper is offline
post #2 of 17 (permalink) Old 01-11-2016, 10:25 PM
Great Unit
Thanks,
Goat Roper
I have the exact same model. It works awesome.
propuckstopper is offline
post #3 of 17 (permalink) Old 01-12-2016, 09:14 AM
Quoted: 98 Post(s)
Looks like a good unit. I still have the same dial-back Snap-on light that I got for my birthday in 1983!! Taken care of, they last a long time.
post #4 of 17 (permalink) Old 01-13-2016, 08:03 PM Thread Starter
Quoted: 106 Post(s)
Thanks guys, I am going to pull the trigger on this timing light.
post #5 of 17 (permalink) Old 01-14-2016, 05:28 PM
Quoted: 98 Post(s)
I pull the trigger on mine every time I use it!
post #6 of 17 (permalink) Old 01-14-2016, 05:40 PM Thread Starter
Quoted: 106 Post(s)
I asked for that one.
Timing is set @ 6 deg., runs like crap and runs hot.
If it is running at 210 when it is 27 outside this isn't going to work this summer when it is 110.
post #7 of 17 (permalink) Old 01-15-2016, 09:44 AM
Quoted: 98 Post(s)
Do Explain, 'runs like crap'. Most 400's that run poorly are running hot, retarded, or both. What cam and where is the cam timing, what water pump spacing, etc. What is your engine vacuum at idle? If it's a hot running turd, my money is on retarded cam timing or ignition timing. Possible mis-installed distributor by a tooth, too. Get us a vacuum reading at idle. With an 068 type cam, should be damn near 18-21"HG.
post #8 of 17 (permalink) Old 01-15-2016, 10:46 AM Thread Starter
Quoted: 106 Post(s)
PM sent.
post #9 of 17 (permalink) Old 01-15-2016, 02:31 PM
chuckha62's Avatar
Quoted: 18 Post(s)
6 Degrees initial is way too lazy to run good and will contribute to running hot.
Obviously, you want to tune for max advance (36-ish degrees @~3200 RPMs) and let the initial fall where it may. Mine currently falls in at almost 14 degrees @ idle, but I'm running a couple of gallons of 110 octane with each tank of 94.
As GeeTee says, try tuning it with a vacuum gauge and see how close that gets you. It usually works pretty well.
chuckha62 is offline
post #10 of 17 (permalink) Old 01-15-2016, 05:13 PM Thread Starter
Quoted: 106 Post(s)
Thanks for the ideas and specs, the engine was rebuilt to run on this crappy 91 octane gas we get out here in Ca. and it has been sitting in the tank for a year so I think I will pick up a fiver of Sunoco 110 @ the parts store up here and put in a couple gallons.
Timing light came today so I need to check that out.
Also the cam was broken in @ 2,000 RPM for 20 minutes and I only have a total of 70 minutes on this engine but with the ice and cinders on the roads up here I can't take it out to test it.
Light up the darkness: aftermarket head/tail light options Orion88 1964-1974 Tempest, Lemans & GTO General Discussion 7 01-17-2014 10:17 PM
new timing light new question 70gto 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 3 04-27-2008 11:23 AM
Lawnmower reccomendations? mlyon The Lounge 5 04-15-2007 04:30 PM
Oil change/reccomendations? GoatBoy4056 2004-2006 GTO General Discussion 28 12-24-2006 06:43 PM
