Total distributor timing. - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-15-2015, 12:53 PM Thread Starter
I have a 1970 GTO with a 400 engine. It is basically stock. Standard distributor except I added Petronics to replace the points. Base timing is set at 9 degrees per the manual. At 2500 RPM it is only advancing by 14 degrees for a total advance of 23 degrees Is this correct or should it be higher?
CMG70GTO is offline
post #2 of 4 (permalink) Old 10-15-2015, 04:47 PM
You should be closer to 36 degrees all in at that rpm. What springs are you using for your advance? Also, is there any pinging/detonation? What octane are you running on this original engine?
BierManVA is offline
post #3 of 4 (permalink) Old 10-16-2015, 11:51 AM Thread Starter
No ping. I am running premium non ethanol gas. I do not which springs I am using. was going to look this weekend. It was originally an auto that I converted to a Tremec 5 speed. I also thought it should be closer to 36 degrees but was not sure.
Thanks for the input.
CMG70GTO is offline
post #4 of 4 (permalink) Old 10-17-2015, 03:03 AM
Agree on "vicinity" of 36 degrees total (no vacuum advance). Which heads are you running? You can get more travel out of your distributor by following the instructions part way down this page => Setting Ignition Timing Curves - Chevy High Performance Magazine (use a smaller bushing, or remove it completely).
A little help understanding total timing NEEDLEZ 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 10-05-2011 08:26 AM
Did I just total my car? Whiteshadow Exterior Discussions 18 12-11-2006 05:09 PM
total miles sno-rydr 2004-2006 GTO General Discussion 12 02-24-2005 03:08 PM
