Tripower on a 67 automatic idle,timing issue - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-02-2017, 07:55 AM Thread Starter
Hello all and Happy New Year . I'm new to the forum and my problem is I rebuilt my 66 tripower using Mike Wasson's Pontiac site and installed it on my 67 automatic,now I can't get idle below 1000. Original vac source was from the Qjet on the center of ventori,not direct manifold vacuum. Traced out possible vac leaks,and found when I clamp off advance hose idle drops? Any body been down this road before,or am I missing something here,possibly dist should be getting ventori vac to work properly and pulling up idle? Any help ,direction is greatly appreciated
eurojeff is offline
post #2 of 3 (permalink) Old 01-02-2017, 11:53 AM
Frank R's Avatar
Make sure the end carburetors are closed completely. Put your hand over their throats, you shouldn't feel any suction. Distributor advance needs to be hooked to a ported vacuum source. Clamping off the vacuum advance should make the idle drop.
Frank R is offline
post #3 of 3 (permalink) Old 01-07-2017, 01:51 PM
Quoted: 98 Post(s)
X2 on making sure the outer carbs are all the way closed at idle. All Pontiacs of this era ran manifold vacuum to the distributor, not ported. Ran a '66 tripower on my '67 for a few years (also a TH400 car) and it ran extremely well. Good luck.
Timing jumps around at idle Bensjammin66 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 15 10-28-2016 11:01 PM
66 389 tripower timing noluck 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 7 10-27-2016 05:35 PM
Idle and timing gtoearl 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 10-31-2015 12:34 PM
Tripower idling issue bowdown232 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 11-06-2014 09:03 AM
Fast Idle Issue daveh70 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 08-23-2009 09:25 AM
