Tripower & distributor size (HEI??) - Pontiac GTO Forum
post #1 of 6 (permalink) Old 11-20-2017, 07:00 AM Thread Starter
Quoted: 126 Post(s)
I am currently using a standard GM HEI unit on a tripower setup and cannot get enough rotation with the distributor to properly set timing . I have tried numerous times to "walk" the distributor and be able to get the timing set, but the HEI cover is so large I have very little room for adjustment. I am wondering if there is a smaller unit that won't hit the back carb and will work well. (I'd really like to use an HEI unit if possible.) Thanks in advance
Chris
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #2 of 6 (permalink) Old 11-20-2017, 01:19 PM
Quoted: 54 Post(s)
There are lots of small cap options. But, I think they all require a remote coil. Some like a factory points type dist with one of the Pertronix Ignitor elec conversions installed. The Ignitor III has a built in rev limiter.
The MSD Ready-to-Run is popular.
https://www.summitracing.com/parts/msd-8528/overview/
https://www.summitracing.com/parts/s...00-1/overview/
https://www.summitracing.com/parts/p...0700/overview/
There are some dist that require a box. I had to buy a replacement box. So, I don't recommend the box, for street cars. Just one more part to go bad. IMO
bigD is offline
post #3 of 6 (permalink) Old 11-20-2017, 06:41 PM
Quoted: 347 Post(s)
HEI and tripower do not go together as you learned. This has been covered in a number of posts and you might find a recommendation within one of the many posts. Use the SEARCH option in the upper right.
I like Pertronix and got one of their electronic distributors and matching coil because I wanted a factory look and not the big HEI cap. If you rather not spend the money on a billet distrib., I would simply get a factory distributor and go with the Pertronix electronic conversion - also have done that and have been satisfied with the results.
post #4 of 6 (permalink) Old 12-05-2017, 06:58 AM Thread Starter
Quoted: 126 Post(s)
Thanks guys! I installed a rebuilt distributor and converted to the Pertonix setup with external Pertronix coil, installed new wires, set the timing (easy), and the car screams .
Current setup:
4 speed Muncie
cij911 is offline
post #5 of 6 (permalink) Old 12-05-2017, 06:16 PM
Quoted: 347 Post(s)
Perfect. Just make sure you have 12volts going to the Pertronix as the instructions say. Factory wiring/points uses a resistor wire and drops voltage down to around 8-9volts.
post #6 of 6 (permalink) Old 12-05-2017, 09:11 PM Thread Starter
Quoted: 126 Post(s)
Yeppers
Current setup:
4 speed Muncie
cij911 is offline
HEI distributor to hood tach alanmay0 1964-1974 Tempest, Lemans & GTO General Discussion 1 07-28-2017 10:52 AM
'65 GTO with GM HEI Distributor ?'s Roqetman 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 8 07-15-2016 02:02 PM
HEI Distributor Bushing GTO1965 1964-1974 Tempest, Lemans & GTO General Discussion 0 05-15-2014 05:08 PM
qustions regarding a HEI distributor danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 05-04-2011 10:31 PM
