Tripower kickdown bracket - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-02-2017, 04:46 PM Thread Starter
I have a 65 GTO tripower with the mechanical progressive linkage and a TH-350 tranny.
I need a kickdown cable bracket. I see that Lokar makes one for about 50 bucks. I've searched the internet and it seems that all the applications that I can find are for a Chevy or a Mustang.
Has anyone here tried one and does it work well with our tripowers?? Plug and play?
Any advice and experience will be appreciated.
grotto107 is offline
post #2 of 4 (permalink) Old 10-03-2017, 04:49 PM
I don't have tri power but I don't think it matters. I hooked up a similar kick-down on my 69 GTO and it was fairly easy. You just attach the bracket by the linkage to the carb on the manifold and the attach the kick-down to the throttle cable. You can then adjust when the kick-down activates by moving the plunger forward or back on the throttle cable. If you need more info let me know...I can probably take a photo if needed.
Good Luck
rkuchar69gto is offline
post #3 of 4 (permalink) Old 10-03-2017, 06:45 PM
Turbo 350 transmissions use a detent cable not a kick down switch.
T-350's didnt start showing up behind Pontiac V8's till the late '60's, optional behind 350 2bbls.
One possible solution is to contact Mike Wasson & see what he can supply to properly allow for the dentent cable on the center carb, it may be a relatively simple fix.
Contact | Pontiac Tripower
post #4 of 4 (permalink) Old 10-04-2017, 04:18 AM Thread Starter
Thanks Guys!
John
Kickdown TV Cable Bracket swap to 200 4r hotcharity95 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 0 05-09-2016 08:03 AM
Quadrajet kickdown connection berg737 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-20-2013 10:57 AM
Kickdown and shifter conversion Beef 66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 05-12-2012 12:40 PM
Kickdown switch adjustment kjk990 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 08-20-2011 01:09 AM
I can't find a 64 kickdown switch & bracket marks64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-31-2009 03:47 PM
