Trouble with cylinder head clearing the alternator - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-23-2019, 03:06 PM Thread Starter
Quoted: 17 Post(s)
Guys,
I’m finishing up the assembly of my Pontiac 400 build and I’m running into clearance issues with the alternator and the heads. It’s a factory alternator and KRE DPort heads. My disassembly photos don’t indicate I’m missing a spacer or anything but the back of the alternator is hitting the head. Am I missing something here? Is it possible the heads are so much bigger that they’re causing clearance issues? Please see the attached photos and thanks for your help.
Mike
ID:	118131   Click image for larger version
70conv is offline
post #2 of 4 (permalink) Old 03-23-2019, 09:09 PM
BLK69JUDGE's Avatar
Quoted: 74 Post(s)
sure looks like a chevy back half
that uses the tube bracket that bolts on to that b oss
and the clocking of the 2 halves looks 90 degrees off
what is the part number on the alternator ??
Scott
BLK69JUDGE is online now
post #3 of 4 (permalink) Old 03-24-2019, 11:18 AM
Lemans guy's Avatar
Quoted: 79 Post(s)
Yes agree, it may fit if it is reclocked. But you want the correct alternator, spaced right to line up the belts,...or they will squeal.
Lemans guy is online now
post #4 of 4 (permalink) Old 03-27-2019, 05:51 PM
Quoted: 119 Post(s)
X2 on the alternator clocking being 90 degrees off. It is.
66 GTO - Alternator Chatter/right alternator? Mikereps 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 04-20-2015 10:55 AM
Hooked headers not clearing adjusting rod oilburner66 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 04-11-2015 07:42 PM
Trouble shifting into reverse after new clutch and slave cylinder installed kmpublishing2 Service, Maintenance and Technical Discussion 5 07-27-2014 12:50 PM
Hmmm...cylinder 4? Cylinder order??? WanaGTO Service, Maintenance and Technical Discussion 3 07-15-2009 09:07 AM
Can't find set of cylinder head bolts for '04 LS1 GTO westell Service, Maintenance and Technical Discussion 10 05-31-2006 12:53 PM
