Type of oil - Pontiac GTO Forum
 1Likes
post #1 of 12 (permalink) Old 04-21-2019, 12:04 PM Thread Starter
Tflorek's Avatar
Quoted: 6 Post(s)
Type of oil
New here have a question about motor oil. I have a numbers matching 70 gto. Motor was rebuilt bored .30 over has edelbrock carb, intake. What should I be running in it for motor oil. Some say 15w40, 5w40, 10w30 what is everyone running. Thanks
Tflorek is offline
post #2 of 12 (permalink) Old 04-21-2019, 12:56 PM
Quoted: 73 Post(s)
It definitely depends on who you ask.
I have a mild 455 with 6x-8 heads & a 2802 Summit cam. I use Rotella T4 15w-40, because it supposedly has about a 1200 count of ZDDP. It's a bracket car. So, when I take it to the track this summer I'll add a bottle of STP oil treatment. Will make the hot oil a little thicker, and will also add a little ZDDP.
Some recommend thinner oil, with a high amount of ZDDP additive already in it.
Some insist on synthetic oil.
https://www.google.com/search?q=zddp...hrome&ie=UTF-8
https://www.google.com/search?q=best...hrome&ie=UTF-8
bigD is online now
post #3 of 12 (permalink) Old 04-21-2019, 01:57 PM
GTO44's Avatar
Quoted: 45 Post(s)
I also recommend a ZDDP additive if it has a flat tappet cam. I always use the Comp zddp additive for any of my customer cars when we do a flat tappet cam install.
https://www.summitracing.com/parts/CCA-159 .
For oil, 40weight or a 50weight unless you’ve a recent rebuild with tighter bearing tolerances. The type of oil is less relevant when your using an additive like above...
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #4 of 12 (permalink) Old 04-21-2019, 02:09 PM Thread Starter
Tflorek's Avatar
Quoted: 6 Post(s)
The rebuild is a few years old sorry should have said that. So shell 5w40 synthetic should be good then and still add ZDDP additive to ?
David Shuff likes this.
Tflorek is offline
post #5 of 12 (permalink) Old 04-22-2019, 02:09 PM
GTO44's Avatar
Quoted: 45 Post(s)
How many miles on the rebuild?
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
post #6 of 12 (permalink) Old 04-22-2019, 07:15 PM
RMTZ67's Avatar
Quoted: 83 Post(s)
Thats the real question. I have a five year old rebuild on a Z28 I own but only 2000 miles. Not sure what's to early for synthetic.
RMTZ67 is online now
post #7 of 12 (permalink) Old 04-23-2019, 02:25 PM
Quoted: 119 Post(s)
Been running Rotella 15/40 for years and years, but it's hot where I am. 10/30 diesel spec oil would be fine as well, or any of the high ZDDP and expensive boutique oils like Brad Penn in 10/30 or 15/40.
post #8 of 12 (permalink) Old 04-29-2019, 10:02 PM Thread Starter
Tflorek's Avatar
Quoted: 6 Post(s)
Ok finally narrowed it down that there is about 700 miles on the rebuild. So what additives and oil still 5w40??
Tflorek is offline
post #9 of 12 (permalink) Old 05-01-2019, 02:00 PM
GTO44's Avatar
Quoted: 45 Post(s)
Non synthetic for sure. Motor needs 2-3k miles on it before before switching over. 5w-40 will work. The viscosity is more about what type of climate/weather you’re in. VR1 racing oil is great and already has the additives. If not get what ever type of oil and add the ZDDP additive.
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
post #10 of 12 (permalink) Old 05-12-2019, 12:29 PM Thread Starter
Tflorek's Avatar
Quoted: 6 Post(s)
Found out that Lucas makes a 10w30 oil for classic cars with high zinc properties. Thanks for the help!
Tflorek is offline
Oil type and capacity Jstreet 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 49 10-29-2009 11:52 PM
oil type for 70 ys 400 even steven 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 07-06-2009 02:05 PM
oil type bigboom44 2004-2006 GTO General Discussion 28 03-13-2009 11:00 AM
oil filter type? vanillagorila Service, Maintenance and Technical Discussion 24 12-31-2007 10:11 AM
oil type sandlakeont 2004-2006 GTO General Discussion 11 04-25-2005 09:09 PM
