Typical vacuum for a 400 ?? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 12-10-2017, 08:11 AM Thread Starter
Quoted: 126 Post(s)
I have set my timing and the car feels strong: initial timing 14 IIRC and total timing is 34/35. My problem is I then checked my vacuum at two locations and am only getting like 13" at idle. The car doe not sound like it has a cam in it, but based upon the heads (low compression 14s) and how it pulls, I am going to guess it has something special.
My question is what do these cars typically see for vacuum ? Thanks
Chris
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #2 of 6 (permalink) Old 12-10-2017, 09:24 AM
very common to measure 16.5-18" of vac @ 1000-1200 rpm in a rel stock cam in a 400. The exception, a RA4 cam without Rhoades lifters, will see low vacuum numbers. by your earlier description of performance, the '68 400 most likely has some type of quick ramp speed cam, a modest XE or Voodoo grind. IF the engine had better flowing even stock big valve heads with proper valves springs, the extra port flow along with better suited cam would pull even harder up top.
post #3 of 6 (permalink) Old 12-10-2017, 08:33 PM
clevelandpartsguy's Avatar
Chris,
I run a Comp Cams XE284, 507"/.510" and 284/296 deg duration in my 74' 400 with stock rebuilt#62 heads, 1.50" roller rockers. I measure about 6 to 8" vacumn at 850-900 rpm idle. Pretty rough idle hard to measure on my gauge as its bouncing around a lot but definitely below 10".
chuck
clevelandpartsguy is offline
post #4 of 6 (permalink) Old 12-10-2017, 09:04 PM Thread Starter
Quoted: 126 Post(s)
Thanks! The idle is super smooth, such that it really has me guessing if it could have an aftermarket cam.
Originally Posted by clevelandpartsguy View Post
Chris,
chuck
Thanks! If I can't get more vacuum, I will likely purchase an electric vacuum pump.
Current setup:
4 speed Muncie
cij911 is offline
post #5 of 6 (permalink) Old 12-11-2017, 09:45 AM
Chris,
yes I've been thinking of getting an electric vacuum pump and installing it this winter, obviously my power brakes are really hard to brake at low RPM. . let us know if you find a good pump and how it turns out, and ill do the same.
Chuck
post #6 of 6 (permalink) Old 12-11-2017, 11:39 AM Thread Starter
Quoted: 126 Post(s)
I will ! There are several options and kits available....I will likely go with an OEM quality (AC Delco or Hella) unit for better reliability, but Summit and SSBC both have "kits" with relays and switches already packaged together.
I will be utilizing brakes from an LS1 and will record pressure to brake booster and line pressure for anyone that is interested.
Chris
Chris,
Chuck
Current setup:
4 speed Muncie
cij911 is offline
67 GTO 400 Vacuum Modulator Seal rickmpontiac 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 08-09-2016 07:36 PM
Vacuum Hose Hookup at "Rotary Vacuum Valve" rvp986 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 08-29-2015 06:12 PM
typical new thread can be found here derekfc Member Introductions 2 06-04-2015 09:47 PM
Engine vacuum and timing for cammed 400 jday240 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 9 10-29-2012 05:08 PM
Typical Lifespan of OEM Struts? Groucho Service, Maintenance and Technical Discussion 8 05-31-2005 07:52 PM
