Vacuum - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-09-2018, 07:24 PM Thread Starter
Quoted: 36 Post(s)
Vacuum
I've seen in pics of Pontiac engines, that one of the bolts that holds down the carb. to the intake, I think maybe the passenger side front or rear, is not only a bolt but also a source of engine vacuum. Apparently this bolt is hollow and I've seen vacuum lines attached. I think I've seen this on mid 60's engines. Would anyone know if this was also possible (source of engine vacuum) on a stock '71 intake with Quadrajet carb.?? Thank you.
Nicholas is offline
post #2 of 3 (permalink) Old 02-10-2018, 04:18 AM Thread Starter
Quoted: 36 Post(s)
Speaking of vacuum, could someone confirm that on a '71 GTO with factory a/c, the source/supply of vacuum for the heater/ac interior control panel, is a black hose with white stripe and the hose for the hot water valve is a black hose with red stripe. I found non 1971 pics and this is where I got my info from. I'm thinking it is probably the same for my year. Why would they change it, but then again?
Thank you.
Nicholas is offline
post #3 of 3 (permalink) Old 02-14-2018, 06:20 PM
My65goat's Avatar
Quoted: 18 Post(s)
You can buy the hollow stud. I got mine from Pontiac tri power. I believe that you can get it from Ames and others.
I'm not sure if it will work with the Q jet? Check it out.
My65goat is offline
Need help from someone that gets vacuum leeps 1964-1974 Tempest, Lemans & GTO General Discussion 13 06-05-2017 01:47 AM
Vacuum Hose Hookup at "Rotary Vacuum Valve" rvp986 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 08-29-2015 06:12 PM
Vacuum Advance kilkm68 1964-1974 Tempest, Lemans & GTO General Discussion 3 08-11-2013 05:18 PM
vacuum lines tom miller 1964-1974 Tempest, Lemans & GTO General Discussion 3 04-12-2013 09:09 PM
Vacuum Leak? Metallifan 2004-2006 GTO General Discussion 2 04-08-2013 09:28 PM
