Vacuum Configuration 1965 AFB - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-12-2019, 02:21 PM Thread Starter
Does anyone happen to know what the correct vacuum configuration is for a 1965 GTO 389 with the AFB carburetor as it relates to the vacuum advance and the brake booster? There is one port on the back of the carburetor and as you know the only two ports in the manifold are in front for the PCV valve. It would seem that a T-fitting on the back of the carburetor would work. I have looked through several restoration books and online and cannot find a definitive diagram or picture of this set up.
cnemike is offline
post #2 of 4 (permalink) Old 01-12-2019, 05:35 PM
This is my setup on my 1965 GTO.Vacuum for distributor comes from hollow carburetor stud on passenger side of car.All the rest come from back of carburetor as photos show.
ID:	117145   Click image for larger version
Bob Conwill is offline
post #3 of 4 (permalink) Old 01-15-2019, 12:27 PM Thread Starter
I have never seen a hollow carburetor stud before, is this original?
Never mind, I just looked up the part on the Ames Pontiac site and yes they do indeed make such a part. Ames part #N188G $13.00
I ordered one today. Thank you very much for your response. I don't know if I would have figured this one out without your help.
Thank you Bob!
cnemike is offline
post #4 of 4 (permalink) Old 01-24-2019, 05:21 PM
Quoted: 98 Post(s)
X2 on the hollow stud. Both my GTO's use them.
grill configuration question Reb 1964-1974 Tempest, Lemans & GTO General Discussion 1 10-04-2014 11:09 AM
'67 Quadrajet Base Gasket Configuration chemnick 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 01-30-2014 06:44 PM
Vacuum leaks, vacuum leaks.. KingJacobo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 11-27-2012 07:51 PM
Fuel system configuration x47544F Engine Discussions 0 06-11-2012 08:54 PM
66 Configuration/Options Questions Koppster 1964-1974 Tempest, Lemans & GTO General Discussion 8 12-12-2008 12:45 AM
