valve covers - Pontiac GTO Forum
post #1 of 22 (permalink) Old 01-08-2016, 05:43 AM Thread Starter
valve covers
I am slowly putting my car back together. Five years ago I purchased some parts for the project. Edelbrock Elite valve covers were in the mix. After installing them, I tried to install my factory a/c compressor. I found that the valve cover is 11/16" too tall, so my a/c bracket that mounts from the intake to the back of the compressor does not reach, and the compressor does not adjust in far enough to install the belt. Has anyone had a similar problem like thiis and if so how did you remedy the situation. I don't want to cut and weld the original bracket.
Thanks for any help in advance,
66
sixtysix is offline
post #2 of 22 (permalink) Old 01-08-2016, 09:21 AM
Longer belt?
post #3 of 22 (permalink) Old 01-08-2016, 09:38 AM
Quoted: 106 Post(s)
Originally Posted by Rukee View Post
Longer belt?
That won't do it, it spans over the valve cover and has the adjuster slot in it.
I barely clears the stock cover so if this one is taller the bracket won't drop down far enough to get the bolt in the slot.
Name:	GTO Assembly 003.jpg
Goat Roper is offline
post #4 of 22 (permalink) Old 01-08-2016, 11:31 AM
Turn those valve covers into wall art and put some Pontiac valve covers back on it.
post #5 of 22 (permalink) Old 01-08-2016, 06:06 PM
Quoted: 98 Post(s)
What Alky said. Install the right valve covers.
post #6 of 22 (permalink) Old 02-29-2016, 02:58 PM
same problem
I have the same problem but the new engine I am installing has Stud Girdle so for me to get AC I most likely will have to go with a March Performance Pulley Kit.
brooknice is offline
post #7 of 22 (permalink) Old 02-29-2016, 05:47 PM
Quoted: 361 Post(s)
Guys that put the stud girdle can't use the stock covers. BUT, I wonder if you could use the valve cover spacers under the stock covers to make it work?
They are not inexpensive, but here are a few in different heights. One might actually work with the application of factory covers. MediceMfg ...Valve Cover Spacers - Pontiac
And of course, Butler has valve covers and a better price on their spacers. Butler Performance - Pontiac Valve Covers
post #8 of 22 (permalink) Old 02-29-2016, 08:31 PM
I have the tall valve cover from Butler all ready. I will try to get to the AC after I get the right headers. I order the Doug d port headers they should be here by Wednesday.
post #9 of 22 (permalink) Old 03-01-2016, 11:57 AM
Lemans guy's Avatar
Quoted: 55 Post(s)
Here is another option...take out the AC and all that firewall mess, compressor as well. Put in the AC delete box and gain all that room....
Now I can fix AC, I have an AC recycle machine and all the tools to do it...
But I like to ride with the windows down and the music up...if you set up your ac vents with a good clear blower..those things really blow the air..and with the vent Windows pretty good.....now I know everyone says their climate is the hottest...
Understand, bug that compressor was for R-12.., and you will likely convert it to 134...not original either, and not as efficient a system designed for 134...
I never thought those old AC system were that great, compressor runs constantly, cooling is up to modern standards, and I like this car to be different than my modern cars, not all coupes up in the glass bubble...
So if you tough it out on some hot days, mostly you won't miss it!.....
And the AC car then gives you the benefits of the 4 core radiator and the return fuel line and a good air vent system....and you won't have that compressor load..or all the freon leaks that every system gets eventually...
There are different ways to do it
Lemans guy is offline
post #10 of 22 (permalink) Old 03-01-2016, 03:26 PM
1968gto421's Avatar
Quoted: 70 Post(s)
That is a tempting thought for my '68 GTO w/factory air. With low freon it's not much use and the changeover to 134 takes money away from the GTO's primary purpose-----performance. One reason I like my '68 is she still has the vent windows in the doors....when I was young that was the "factory A/C" on most cars. True, in SC having air is really nice but this is not my daily driver (which does require A/C) so why be a wimp on weekend cruising. Put the windows down and hear those pipes and Q-jet secondaries! (No more burned hands getting out spark plugs from behind that damn compressor.) Thanks, LeMans guy!.........(where do I find a good A/C delete box?)
1968gto421 is offline
Valve Covers xconcepts 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 10 10-01-2012 06:11 PM
LS2 Valve covers SWGOAT 2004-2006 GTO General Discussion 3 03-06-2012 10:37 AM
67 GTO valve covers PisnNapalm 1964-1974 Tempest, Lemans & GTO General Discussion 2 10-11-2010 09:32 PM
M/T Valve Covers jpdog357 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-13-2006 11:46 AM
