What do you make of this timing issue? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-06-2018, 05:51 PM Thread Starter
Quoted: 9 Post(s)
A couple months ago I got rid of the Holley carb that was on my 68 and replaced with a QJet. When I did that, I checked my timing to make sure all was dialed in, and it was about where I wanted it - 36 all in and ~15 at idle. I had made a big timing adjustment to 36/15 a few weeks before the new carb.
Last week, I did an oil change, replaced plugs and did a compression check - 185-190 all around.
I put a timing light back on just to see make sure all was dialed in, and when I get the engine to around 2500, the light goes intermittent. I get a nice steady flash at idle and on up through 1000's, but then somewhere just north of 2k, the light starts going intermittent.
I put the light on another car (68 chevelle 383 stroker) and I get a nice steady flash all the way up through the RPM range.
The engine doesn't sound unusual and runs pretty dang good. But now I'm thinking something is a miss.
Am I losing a cylinder at higher RPMS? I'm thinking I must not be firing right - should I be looking at a new distributor?
Also - I'm running an HEI distributor now...
What do you think??
Thanks for any insight...
Bredfan is offline
post #2 of 2 (permalink) Old 01-14-2018, 08:25 PM
Quoted: 126 Post(s)
Sounds like it is the timing light, since the engine is running fine. It could either be a pickup or power / ground specific to your car (since the other car worked). Have you tried a different timing light ?
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
Tripower on a 67 automatic idle,timing issue eurojeff 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 01-07-2017 01:51 PM
1966 Ignition and Cam Timing Issue Stretch 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 14 06-10-2014 12:06 PM
Help me timing or carb issue my67goat 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 19 04-08-2013 05:07 PM
Another timing issue, or is it....... 68greengoat 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 32 04-07-2010 07:56 PM
