where exactly do these water pump sleeves go? - Pontiac GTO Forum
post #1 of 10 (permalink) Old 10-03-2018, 11:14 AM Thread Starter
Quoted: 17 Post(s)
Guys,
I'm building a 400 stroker for my 70 conv and I have a question on where exactly do these water pump sleeve things go. Do they go directly into the timing chain cover and then the divider plate and water pump go over them or do they go between the water pump and divider plate? thanks for your help.
Mike
70conv is offline
post #2 of 10 (permalink) Old 10-03-2018, 11:48 AM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
they go directly into the timing cover
no sealer
they do have new rubber seals correct?
BLK69JUDGE is online now
post #3 of 10 (permalink) Old 10-03-2018, 01:24 PM Thread Starter
Quoted: 17 Post(s)
Yes they are brand new. Thanks for your reply.
70conv is offline
post #4 of 10 (permalink) Old 10-03-2018, 09:26 PM
Originally Posted by 70conv View Post
Guys,
Mike
This image shows where they go. One is inserted already, the other is not.
post #5 of 10 (permalink) Old 10-06-2018, 02:26 PM Thread Starter
Quoted: 17 Post(s)
Can you tell me where these rubber seals go? Are they supposed to be used with the sleeves in some way? I put the sleeves in and mounted the water pump then discovered these in the gasket kit. Not sure what they’re for. Thanks for the help.
Mike
ID:	115741   Click image for larger version
70conv is offline
post #6 of 10 (permalink) Old 10-06-2018, 05:12 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
bummer
I asked you about those if you had new ones in the sleeves ....
also did you clearance the pump impeller to the plate ?
and do you have a tin or cast impeller ....
tin ones dont cool very well
many cast impellers have been topped and the tops shaved after rebuilds
and dont cool welll also
those go inside the sleeve and mate to the holes in the divider plate .......
Scott
post #7 of 10 (permalink) Old 10-06-2018, 05:25 PM Thread Starter
Quoted: 17 Post(s)
Thanks for the info. Def a bummer but no biggee. I’ll just have to pull the water pump off. I thought the seals you spoke of were actually in the sleeves so since they were new I thought I was covered. The water pump is a perf after market and it has a cast impeller. The divider plate is by Tin Indian I think it’s steel. I checked the clearance of the plate prior to install and it was good. Two steps forward one step back. 😬
70conv is offline
post #8 of 10 (permalink) Old 10-06-2018, 05:27 PM
Quoted: 106 Post(s)
Goat Roper is offline
post #9 of 10 (permalink) Old 10-06-2018, 05:44 PM
Quoted: 347 Post(s)
Originally Posted by Goat Roper View Post
X2 If you plan on working on your car, the Service Manual should be the first part you ever buy. The cost of it will save you money in the long run and provide the know how in repairing and rebuilding your car.
post #10 of 10 (permalink) Old 10-06-2018, 06:07 PM Thread Starter
Quoted: 17 Post(s)
Ok I’m def a dummy. I just pulled the WP off and the seals are in there. I mentioned that the sleeves were new I guess when you buy them they come with new seals inserted but when I got the gasket kit it had them in there too. 😡 oh well
70conv is offline
Tie rod adjusting sleeves extinctmake 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 12-26-2014 06:03 PM
What does the on/off switch do exactly? batmans 2004-2006 GTO General Discussion 11 11-15-2010 03:44 AM
Tie rod sleeves Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-29-2010 09:00 AM
"sleeves" in the water pump. badams_iyns Service, Maintenance and Technical Discussion 1 02-16-2008 09:12 PM
What exactly is CAGS and what does it do? red_wing_2121 2004-2006 GTO General Discussion 4 10-20-2004 02:40 AM
