worn cam bearings, fresh rebuild - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-05-2014, 09:09 AM Thread Starter
SPCMarty's Avatar
Y'all may remember me asking all sorts of questions trying to rebuild by 557 cast code 400cui. Well I had finally put it all together, and thought i had done alright. Until i noticed a light ticking sound, which while trying to find the cause i found a cam bearing was starting to come apart. This engine only had 600 miles on it and i used Amsoil SAE 30 break in oil, and i didn't mistreat it.
I am wondering if i just had a stroke of bad luck, or maybe i missed something some where. A shop handled the major rebuild process with the rotating assembly and cam bearing change. I am hoping all i need to do is replace the bearings and choose a new camshaft kit. Can anyone offer advice on what i should inspect or pay close attention before i begin the work?
1971 LeMans 350ci 2Barrel Carb
B. Co 1-22 4ID OIF 2008-09
SPCMarty is offline
post #2 of 3 (permalink) Old 09-05-2014, 10:25 AM
Did you pull the cam out to see the bearings? Possibly the oil hole in the bearing was not lined up right with the oil hole in the block?? I do believe the motor will have to come out to change the cam bearings.
post #3 of 3 (permalink) Old 09-07-2014, 12:36 AM Thread Starter
SPCMarty's Avatar
I haven't found the time yet to pull the camshaft. Metal sticking out between the bearing and cam gave away the fact it was coming apart.
I'm almost thinking I may have caused this, I had tightened the roller rocker nuts to factory stamped rocker specs, a move that bent all 16 push rods. Maybe there was enough stress put on the bearings.
SPCMarty is offline
Teething issues with a fresh engine/trans rebuild....66 Lemans BillyB 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 03-24-2013 10:22 AM
Feeling for worn clutch smitty2919 Drive train, suspension, alignment and brakes. 5 02-02-2012 12:17 PM
Fresh Meat Ponyboy Member Introductions 4 04-21-2011 09:48 PM
18K miles and all tires are worn on the inside tire wall! Silver2006GTO Wheels and tires 5 05-23-2010 12:16 PM
Get your Fresh Virgin here jesco Member Introductions 5 08-23-2006 01:38 PM
