Wrench size for exhaust manifold bolts - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-15-2012, 08:53 AM Thread Starter
par4n1's Avatar
I cant locate a wrench to loosen any exhaust minifold bolt. Could it be they have rusted down or the heat through the years has changed the head size?
Anyone else had this problem?
par4n1 is offline
post #2 of 5 (permalink) Old 01-17-2012, 10:08 AM
Totally possible. You could try a 6 point box end wrench. If that doesn't work then maybe go to the next size smaller or even a metric size. If you still can't get them, they have some extractors you may be able to use. Once you get them out, be sure to replace them all.
post #3 of 5 (permalink) Old 01-17-2012, 01:40 PM
Quoted: 100 Post(s)
I agree. Try a 6 point 9/16. Also, make sure the locking tabs are bent back out of the way of the bolt heads, if it's still stock.
post #4 of 5 (permalink) Old 01-17-2012, 09:02 PM Thread Starter
par4n1's Avatar
PLAY OFFS, PLAY OFFS? Locking tabs? Geesh that has to be it. Funny no tab in sight they must all be on the back side. I will have a look tomorrow
par4n1 is offline
post #5 of 5 (permalink) Old 01-17-2012, 10:34 PM
Quoted: 100 Post(s)
Play off wtf???
1968 exhaust manifold bolts izzy412 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 04-30-2011 11:15 PM
manifold bolts 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-19-2010 07:53 AM
ft. Lb. torque for intake manifold bolts marks64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 07-02-2009 10:55 AM
exhaust manifold bolts izzy412 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 05-07-2009 07:45 AM
Wrench Size for Tranny B/U Switch? Groucho Drive train, suspension, alignment and brakes. 5 04-19-2006 11:37 AM
