#16 heads - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-31-2012, 10:10 PM Thread Starter
#16 heads
Is anyone running a 400 with #16 heads, on PUMP gas ?? If so what combo do you need to run?? (lotta talk that they create too much comp.)
Thanks, Duck..
1coolduck is offline
post #2 of 6 (permalink) Old 11-01-2012, 05:09 PM
It can be done on a 400, much harder on a 455. 16's have a nominal chamber size of 72 cc's, so to get the needed clearance volume the "best" solution is usually to run dished pistons.
post #3 of 6 (permalink) Old 05-21-2013, 10:19 PM
Quoted: 391 Post(s)
If you are rebuilding your engine, Bear is correct. Usually you get the correct pistons with more cc's, aka dished pistons, or you can talk with a cam manufacturer who can "bleed off" some of the compression -type in "static compression verses dynamic compression" into your search engine and get ready for a lesson in compression ratio's. Another trick I have not seen in a long time used to be to add a water/alcohol injection system that was supposed to cool the intake charge on higher compression engines as well as give a little more power. Ever notice how your car runs stronger on a good cool damp night? I have seen a how-to article where the windshield washer pump/container was used and misted into the top of the carb via the air cleaner lid. I have seen kits for sale as well. It kicks in during wide open throttle. Might look into that as an option. I am considering one myself just as a precaution should I ever need it -even though I will have a reasonable compression ratio to run pump gas.
post #4 of 6 (permalink) Old 05-22-2013, 09:45 PM
pontiacmatt's Avatar
I run pump gas ( premium/ 10 percent ethanol) in mine but don't know if engine was ever rebuilt before I got it 20 some years ago. I drive like an old lady anyway.
pontiacmatt is offline
post #5 of 6 (permalink) Old 05-23-2013, 06:27 AM
Try using Ethanol Treatment. I use Sunoco 93 oct it has 10% corn/water. . I use Lucas's Ethanol Treatment 1 oz per 5 gallons. I noticed a difference in detonation. Their treatment can be used on E-85 it states, but there is no way in hell that garbage is going in any of my vehicles.
post #6 of 6 (permalink) Old 05-23-2013, 08:45 AM
Also, consider this: In my 461, the difference between 9.2:1 compression and 10.0: compression, with no other changes made, is only worth a whopping 8 hp. (in an engine that's already over 500 hp). That makes pushing the envelope on compression to the razor's edge just not worth it.
Heads on 389 help Billoney 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 04-04-2013 09:08 AM
edelbrock heads or 6x heads bobby326 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 08-23-2010 12:40 PM
#96 heads or not? assasn2k 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 03-11-2009 06:42 PM
ls6 heads? bassist3453 Engine Discussions 9 07-25-2008 08:27 PM
