1965 GTO Valley Pan - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-07-2018, 10:31 AM Thread Starter
1965 GTO Valley Pan
Being a "newby", I want to thank all of you for sharing your time and experience with those of us who love GTO's. I'm in the process of having my 1965 GTO restored and have a question about the valley pan. The car originally had a 4 brl carb. I bought a tri power intake and carbs some years ago and thought there was a difference in the valley pan for the tri power. I can't find anything definitive in the research I've done. Any advice or comments would be appreciated.
sidthecpa is offline
post #2 of 5 (permalink) Old 06-07-2018, 12:22 PM
BLK69JUDGE's Avatar
Quoted: 62 Post(s)
welcome
fairly sure you need the style with the pcv in the rear and your good to go ...
Scott
BLK69JUDGE is online now
post #3 of 5 (permalink) Old 06-07-2018, 09:49 PM
Quoted: 126 Post(s)
Scott
The 4bbl will fit but if you are redoing the motor or taking the intake off, just get one for the tri power as it fits better.
Here is mine:
Name:	Motor from top.jpg
ID:	113385   Click image for larger version
Name:	Motor front.jpg
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #4 of 5 (permalink) Old 06-22-2018, 12:18 PM
Quoted: 99 Post(s)
All '65-'66 valley pans are the same, with the PCV in the rear. No worries. Be sure to peen the pan edges flat, glue the gasket to the pan only and let it set before you install. When you install, torque in stages, and go super, super light so you don't suck in and warp the pan or do what a friend of mine did and break the boss in the engine block. I use flat washers coated with RTV under both hold-down bolts to prevent leakage, too. Good luck.
post #5 of 5 (permalink) Old 07-05-2018, 11:52 AM Thread Starter
Thanks for the info.
1966 GTO valley pan sonic22 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 09-08-2016 12:20 PM
Valley pan orelog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 08-29-2014 09:33 AM
1966 gto - Valley pan gasket replacement Berto504 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 08-08-2014 06:06 PM
valley pan Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 13 08-05-2011 01:41 PM
valley pan Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 01-31-2011 03:04 PM
