1965 Power steering Conversion - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-10-2012, 09:23 PM Thread Starter
I need help ,i have a 65 gto with a 400 with 67 firebird heads i am wanting to convert to power steering i currently have coeerct pulleys one groove for ac one for alt room for ps pump. My question is what brackets are needed along with steering box also is there need to change pittman arm ,what years of parts will work. If i could see a picture i may be able to figure it out but unable to locate one, thanks for any help
Yancey60 is offline
post #2 of 3 (permalink) Old 10-11-2012, 09:10 AM
Quoted: 118 Post(s)
Pitman arm, gearbox, pulleys, and brackets are all different. Not a quickie swap. Best bet is to get it all at once from a wrecked car. Pretty much any Pontiac A body '64-72 will work.
post #3 of 3 (permalink) Old 10-11-2012, 03:57 PM
rickm's Avatar
Quoted: 5 Post(s)
your timing cover, and or waterpump is going to govern which year power steering components are going to work on your motor. otherwise pulleys wont line up with each other. proceed with caution . first identify timing cover on your motor. rickm.
rickm is offline
best power disc brake conversion for a 67 lemans virginiavenom 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 15 02-28-2011 01:36 PM
65 GTo manual steering to power steering? d.reese 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-10-2009 06:51 PM
1965 Front Brake COnversion BajaGTO 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 03-11-2006 07:10 AM
