1966 389 Tripower Vacuum question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-04-2018, 04:12 PM Thread Starter
opieone28's Avatar
Hi everyone, I am hoping someone knows about the vacuum lines on my 1966 tripower. I recently purchased this old beauty and I am starting to restore. The engine runs not bad. But on the rear carb passenger side there is a carb stud that has a hole in it. I think it is supposed to be capped because my car is manual transmission. The previous owner short piece of vacuum hose on it and jammed a tee in it.
doesn't see like that is correct. Can someone tell me what vacuum hoses need to be run and where or if there is access to a vacuum schematic.
any help is greatly appreciated.
opieone28 is offline
post #2 of 3 (permalink) Old 07-04-2018, 07:41 PM
Quoted: 367 Post(s)
Lot of great info on our forum is you use the "Google Custom Search" box in the upper right. Click on this link for example: https://www.gtoforum.com/f12/1966-tr...acement-78762/
PontiacJim is online now
post #3 of 3 (permalink) Old 07-11-2018, 05:53 PM
Quoted: 102 Post(s)
Usually, that hollow stud is there to supply vacuum to the vacuum advance can on the distributor.
where to buy 1966 tripower center carb buish 1964-1974 Tempest, Lemans & GTO General Discussion 8 06-08-2017 08:19 PM
66 389 tripower timing noluck 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 7 10-27-2016 05:35 PM
Vacuum Hose Hookup at "Rotary Vacuum Valve" rvp986 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 08-29-2015 06:12 PM
Vacuum leaks, vacuum leaks.. KingJacobo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 11-27-2012 07:51 PM
Fuel Delivery for a 389 Tripower 389Tripower 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 09-26-2011 09:52 PM
